I have been pottering around.....I've owned the van for approx 25days and with all its faults I have fallen in love...
Call me old fashioned (45 in Jan) I am a great believer in preserving and making the most of what you've got....
I started with underneath by wire brushing scraping allsorts of nasties, gunk and more gunk...treated surface rust with VACTAN..most of the factory underseal protection had weathered/worn away so by hand I painted/covered with Waxoil. One thick healthy coat...used approx 3L.
I then got to work on the arches and whatever else I could find...Decided to take the seats out..glad I did! Here are a few pictures.
In case your wondering the black patches is the work of VACTAN...Highly recommend this stuff...
Drivers side..
Passenger side with small filler repairs to the step and arch. I know I will have to get the welder out and stick fresh steel in the future....I am confident I will be ok for a few years as I have caught and treated the rot just in time. (looks worse than it is!)
I have water coming in through the engine bay bulk head...probably got a couple of rot holes allowing it in..once I start on the engine I can get better access and deal with whatever lies beneath
Here is the repair I did to the step..not finished yet
Now for the rest of the treated and filled bits..remember underneath has now been filled as well as treated with Waxoil..so should get a couple of years before Mr MOT pokes a hard sharpy thing through and fails it..
Here is a picture showing My rust bashing friend...
Now for the outside..wheel arches 70% had already been filled..I tidied up using a grinder and filling in sharp edges...coated with a red oxide primer..not the most glamourous..but sealed for now..
Offside view of the van...the rear arch area where the mud flaps are mounted had rotted out so I practically rebuilt it using s/s shim steel and filler. Short term I know..but should do for good couple of years
I will be giving it a paint job to make it look less like a van from a travellers site..Going to use a Combi colour RAL and roller it on. Not sure on colour..lets get this winter over with first.
Overall I am pretty chuffed with the work I have done...I have caught the nasty bits just in time, and what I have caught I have treated and treated some more.
Now for the mechanical side of things...
The engine has from early inspection has never had its belts changed...I have only drove it 10miles since buying..I won't be driving until the engine has had a major service....The drive was sluggish and following inspection I can understand why...
Lots of oil has leaked on the block from the rocker cover.(hopefully not head gasket)...sump gasket appears to be failing...power steering rack (section between the front wheels) is saturated in oil.(hopefully the rear crank seal is ok.
From reading the forum a good service will bring a smile to my face...(I plan to change oil,fuel,air filters,all belts, water pump,thermostat, uplift pump, sump gasket,rockercover gasket. Sort out the tappets, however..never done this before so a link showing this would be most helpful..I believe there is one on this forum for a 2.0l engine..is there one for a 2.5L.
I want to clean the engine first and determine the engine code..I have feeling its a 4HC..I have researched where to go for parts but I don't feel happy..please can you recommend a member who trades, alternatively can you offer a good contact for me to call today if pos so I can get things rolling. Thanks in advance guys..I have tried Transit Parts UK...Asked for a price 10days ago...still waiting..
My local Ford dealer is as usful as a choclate cod piece and showed no interest atall...12 year old van...we need to order your parts and ther are several different belt set ups..cock..plus really expensive...I will pay top prices for cam belts..Other parts I can get too easily I will go on recomendations. I am not a cheap skate..just like the next man when it comes to making a saving..I have a wife and two children
Couple of pictures to ease the burden of my constant dribble
part of the sump with oil doing its thing
not the best picture..notice the oil build up on the rack
Rocker cover area
I believe I have a bosch pump..i think it is either a 626 or 624..I canna remember captain..this is the fuel filter..how easy is it to take these off manual covers a different style to mine!
Thats it for the time being..Going to take the rad out and bits off so I can get better access to cleaning...so long as the rain holds off...just starting to recover from a bad cold...first in two years...don't like it and my wife wants me to keep warm and stuff..
Thanks for looking and any help, advice, happy stories etc...all welcome
Tom
