Agent Orange
Re: Agent Orange
Postby Tango330 » Tue Jun 23, 2015 1:43 pm
Thanks for the offer Martyn, will bear that in mind :)
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Re: Agent Orange
Postby martynx » Tue Jun 23, 2015 1:46 pm
Tango330 wrote:Thanks for the offer Martyn, will bear that in mind :)
8) 8)
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Re: Agent Orange
Postby Tango330 » Fri Jun 26, 2015 8:54 am
martynx wrote:No problem , only other mod was the speed sensor wiring at back of gearbox needed extending - 5 minute job. And I needed the 6 speed gear change cables and stick assembly but that was plug & play.
I saw a set of cloth ST seats go for 150 locally on eBay so they do come up at a decent price occasionally . :-)
Hi Martyn
More questions I'm afraid :?
I'm pretty sure I'm going to swap the gearbox, but a couple of things I need to confirm.
slave cylinder - is it external on the 5 and internal concentric on the 6 :?: Is the pipe work an easy swap :?:
Will the 6 mate to my existing clutch flywheel setup :?:
I have a stick/selector on the way, no cables as yet, and I'll probably get a spare prop to modify.
Anything else I need to consider :?:
Sorry Mate.
T330 RWD now sold
Tango330
Re: Agent Orange
Postby martynx » Fri Jun 26, 2015 10:36 am
Ask away Man , no worries :wink: You will need the 6 speed clutch & flywheel.. I cant remember any dramas on the slave cylinder piping, have a feeling its plug & play / same system etc ..the cables were cheap new like 75 quid a set or something.. :) :)
martynx
Re: Agent Orange
Postby Tango330 » Fri Jun 26, 2015 2:31 pm
Cheers Martyn, appreciated :)
But I can't use the 6 speed flywheel apparently, something to do with crank sensor :?:
T330 RWD now sold
Tango330
Re: Agent Orange
Postby martynx » Fri Jun 26, 2015 2:59 pm
Tango330 wrote:Cheers Martyn, appreciated :)
Hmm not sure on that - but mine ran 140 software happily as a 5 Speed.. suggesting the output signal from the sensor was the same? what have you heard about it exactly ?
martynx
Re: Agent Orange
Postby Tango330 » Fri Jun 26, 2015 3:05 pm
Did a trawl for posts about swapping from 5 to 6, and didn't come up with much, but found some stuff from 2009 where someone had tried it, but that due to the sensor being in a different position it couldn't register and the software refused to start the motor :shock:
there was some discussion bout moving sensors etc., but it was over my head to be honest. Now I can't find it :roll:
Trouble is, I'm trying to do this and finish my house extension, and deal with call outs from the fire service too. Too many jobs :?
T330 RWD now sold
Tango330
Re: Agent Orange
Postby loot » Fri Jun 26, 2015 3:19 pm
Tango330 wrote:Did a trawl for posts about swapping from 5 to 6, and didn't come up with much, but found some stuff from 2009 where someone had tried it, but that due to the sensor being in a different position it couldn't register and the software refused to start the motor :shock:
We'll find out soon mate, we're having a discussion about it over some cucumber sandwiches. 8)
Ids map here
loot
Re: Agent Orange
Postby Tango330 » Fri Jun 26, 2015 3:53 pm
Nice, used to like them with a bit of sugar on the cucumber 8)
T330 RWD now sold
Tango330
Agent Orange
Postby martynx » Fri Jul 03, 2015 11:57 pm
Inlet has been improved a bit this eve :) on 200's the Egr feeds into a separate MAP sensor housing and has a chimney / funnel protruding in which takes up a fair amount of room. I cut the protrusion away and filled up the hole with black body filler.
I used an EGR blanking plate for the outside screwed onto remnants of the Egr feed pipe.
Feels more urgent to drive but I emptied the back out as well this eve , so the 40 kilo reduction may be the reason;)
Been meaning to do it for ages so I'm pleased it's sorted ready for North Weald this weekend.
I wonder how heat tolerant body filler is ?!
martynx
Re: Agent Orange
Postby loot » Sat Jul 04, 2015 7:17 am
Should do OK with heat in itself but if it's standard filter then the expansion tends to crack it if applied to something that Is likely to have slight movement :-(
If that does happen tho you could probably use a sealant type stuff .
I think it should be ok tho.
:wink:
Ids map here
loot
Re: Agent Orange
Postby Tango330 » Sat Jul 04, 2015 7:41 am
Best of luck this weekend Martyn, looking forward to seeing your results.
I'm on call, so can't make it again :?
T330 RWD now sold
Tango330
Re: Agent Orange
Postby martynx » Sat Jul 04, 2015 9:41 am
loot wrote:Should do OK with heat in itself but if it's standard filter then the expansion tends to crack it if applied to something that Is likely to have slight movement :-(
:wink:
It's bumper repair stuff LOL , hence it being black. Smells exactly the same as P40 or whatever regular body filler is called :-)
We use what we have ;)
& cheers Tango , but you should bring your fire engine along , that would be something to see that go down the strip!!!
martynx
Re: Agent Orange
Postby kulataz » Sat Jul 04, 2015 9:53 am
Have you gota new phone number? Text a few times....lol
kulataz
Re: Agent Orange
Postby martynx » Sat Jul 04, 2015 9:54 am
Same one blood - 07956555666:) how's that tuning settling in ?
martynx
