Webby1989 wrote:What kind of changes have you seen in mpg after the diff ratio change?
I only did 50 miles in it before I had it done. I'm getting 33 at the moment. I could get more if I was more careful...
alz4321 wrote:Big Ben 83 wrote:Looks like your doing everything i want to do to mine, I've just run out of money to do the inside and it's to useful as a van at the minute.
I got mine from MVS. Do you live in Sheffield. Looks good btw, keep up the good work.
I'm in Aberystwyth in mid Wales so it was a bit of a trek to Sheffield but they seemed to prep them better than other places so it was worth it. I'd thought of putting a sport kit on like yours but I can't justify the money at the moment. I'm intending to make everything removable in the back so I can still use it as a van if I need to.
looneyfitter wrote:You could expanding foam the gaps then cut it flush
