by robbie.cee » Fri Feb 24, 2017 5:21 pm
Spent today thinking about exhausts but picking old sealant and plumbers mate and removing a leaky side rail.
It was the cause of the damp which happily has dried out now after i gaffer taped up outside. Dug out all old sealant from rail and ran 2 massive thick beads of mastic in the channels proud of the line and also ran a bead of sealant along the panel joins on wall of the caravan before re attaching the rail amd adding a few extra screws where needed. Wiped off excess sealant and ran another bead above and below rail.
Be well shocked if that leaks in next 4 years!
Whilst there noticed more broken screws on main corner rail at front where 2 panels seperated so pumped it full of sealant and new screws all back in place .
Ran out of sealant then so will go over front rail again soon!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
