well heres another report on progress of this project, mind you it ill be the last update for a while. i had my back operation on tuesday after having problems on and off for a long time. i finally bit the bullet to have it done and all seems to be going well so far.
it will be a couple of months at least before i can get back at any sort of manual work if im to give my recovery a proper chance.
so now that the boredom is kicking in i thought id update this thread as far as i got before packing up!!
repairs to the scuttle panel is almost complete. i put a shot of paint on the fresh metal to hold the rust back a while when its sittin up
one wee bit yet to be done.
i recently invested in this little toy which is a great help on those small hard to access repairs.
next we made a start on figuring out getting the front end panels sitting in place.
i came across a nos bullnose front panel on my travels which should give good reference for the fibreglass wings etc..
the l/h wing didnt look too bad but the r/h side did not look that at home!! its going to be a bit of a challenge getting everything right as the cab has been chopped about so much. i guess the fibreglass wings should make it a bit easier if stuff needs altering.
i used every bit of help i could find to figure out gaps and positions from pics etc!
to get some more measurments i hauled up one of my donors from the yard which even though isnt in great shape has untouched front end panels.
we set about making up a sort of "jig" that could be mounted on common positions on both vans to take some measurements for where the wings should be sitting to be in the more or less correct position. it proved helpfull as theres more or less no original original points left to measure off on the project truck!! :rofl:
after a lot of shuffling and panel swapping etc we got things looking half decent. still a nice bit to do on this but its looking do able at least. the doors now need to go back on to double check everything.
meanwhile i got the piece of sheet metal folded which will taper off at each side to box off the front chassis crossmember behind the bullnose fibreglass valence which will only be there for looks rather than mount the bumper brackets as id did originally. i intend to weld tubes through the box section behind the valence which will take long bolts through and will be strong enough to hang the bumper brackets off and still look original.
the old donor tranny will also hopefully supply the outer valence corners as they look pretty decent. will see when theyre chopped out, but thats a bit off yet im afraid, still a lot to do!!
