Conrod's new Sundowner
Re: Conrod's new Sundowner
Postby conrod » Fri Sep 05, 2014 3:14 am
My new NZ number plates turned up in the post today, old Australian plates for comparison:
and new NZ plates :) :
conrod
Postby Neil » Fri Sep 05, 2014 7:19 am
was the roeberk door mirrors from new or have they been added after :?:
Neil v6
Neil
Postby conrod » Fri Sep 05, 2014 10:14 am
those door mirrors are standard fitment on the Sundowner :)
conrod
Postby Altransit » Fri Sep 05, 2014 11:02 am
Love the plates, how spooky is that, Conrad 8) 8)
Postby conrod » Fri Sep 05, 2014 11:56 am
Altransit wrote:Love the plates, how spooky is that, Conrad 8) 8)
yep, "Rad" used to be a nickname for me back in school :) I thought about "SNDWNR" which is still available, and I already have "CONROD" but decided to run with the original plate ''RAD250" as everything was "RAD" back in the 1970's :)
conrod
Postby Neil » Fri Sep 05, 2014 4:48 pm
those mirrors were sold here in the 70 s by custom shops
Neil v6
Neil
Postby transitandy » Fri Sep 05, 2014 11:02 pm
8) 8) 8)
Postby conrod » Sun Sep 07, 2014 6:25 am
Replaced a couple of rusty frost plugs, fitted a new set of spark plugs, gave the engine a clean, and took it for another road test. Went a little bit better. Checked the throttle and discovered it was only getting half throttle, so adjusted it up, took for another road test, and it goes MUCH better now! Happier today :)
conrod
Postby bambi mk 1 » Sun Sep 07, 2014 11:29 am
bambi mk 1
Postby conrod » Mon Sep 08, 2014 9:34 am
Replaced the front indicators with a NOS pair I had "in stock", and fitted a pair of headlight surronds that I had minted up previously.
Old tail light, bleached clear by the hot Aussie sun, and badly cracked:
More NOS goodness, I am also fitting the reversing lights that I had stashed away, although not fitted to the Sundowner they were an option on the Mk2, and the wiring and screw holes are already there, so basically plug'n'play :)
conrod
Postby conrod » Mon Sep 22, 2014 10:24 am
Spent a few hours on the van yesterday. Decided I did not want the LPG fitted, so proceeded to remove it all. Only took a couple of hours to get everything out. Discovered the tank was full,(it was damn heavy!) and as I dropped it out on the ground the back of the van jumped up, must be a good 30mm higher in the rear now, sits level instead of bum down :)
conrod
Postby Altransit » Mon Sep 22, 2014 1:56 pm
Even faster now :?: :mrgreen: 8)
Postby conrod » Mon Sep 22, 2014 8:59 pm
Yep, I reckon there was 100kgs in that lot, plus the restriction from the mixer ring is removed :) I don't intend to do big mileage in the van, so fuel savings will not be huge. Plus it all looked a bit ugly, and I want to restore this van to original :)
conrod
Postby Altransit » Mon Sep 22, 2014 9:26 pm
conrod wrote: I want to restore this van to original :)
8) 8) :mrgreen:
Postby conrod » Fri Oct 31, 2014 7:11 am
Haven't touched the van for a while, but got back into it last week. Wheels were looking a bit second hand, so I stripped the tyres off, had the rims powder coated, and fitted the new tyres I bought, old school BFG T/A's in 225/60x14 for the front and 245/60x14 for the rear. Despite powder coating being a pet hate of mine, they were done this way from new, and painting was going to be very expensive, so I decided to go this way. I have the diff out at the moment, changing the ratio from the 2.7 that the previous owner fitted (ridiculously tall in first and reverse) to a more clutch friendly 3.45 from an EL Falcon. Van has a T5 box fitted, so will still have long legs in fifth gear. It is going to be used in a TV mini series set in the late 1970's, so getting it ready for its starring role
conrod
