Restorationvanman wrote:Doesn't look a bad old busshame you hadn't have been aware of what you needed/wanted when you were over this way (I'm only 15mins from Newcastle) as I have most of the stuff you mentioned above (4 good engines, wings and Ifs front bits incl new shocks and springs) not to mention clutches and loads of other stuff
Bryan wrote:Here's some more photos of it:
The passenger side rear wheel arch is a real piece of work - bodge after bodge. I'm not even sure if a replacement wheelarch panel will have enough metal on it to attach to any solid steel!
