Mk6-mk7 Conversion No 2 2006 Transit T280 100ps (PIC HEAVY)
Re: Mk6-mk7 Conversion No 2 2006 Transit T280 100ps (PIC HE
Postby paul2012 » Thu Nov 19, 2015 10:25 pm
Darren.w wrote:
paul2012 wrote:Yes they will fit. As Previously said require a slight alteration fir them to fit properly.
I used a Dremel :wink:
Same fitted to both this Mk6 conversion I did for another member & my mk6 conversion. :arrow: viewtopic.php?f=27&t=150664&start=570#p1346601
Hi, got myself a set of them :D do you have any pictures of them once you had modified them and was the wiring already there for them ?
I don't have any pics shown the mods. Wiring is not there. Easy to wire up, connect to headlamp switch for position lights (side lights) :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Brains_transit » Thu Nov 19, 2015 10:31 pm
I had a laugh looking up marker lights on eBay a pair was £40 and £25 each both used condition :lol:
Brains_transit
Postby Darren.w » Thu Nov 19, 2015 10:37 pm
Yeah saw them ones on eBay. I got mines from a guy I know. Gave him £20 for both
Darren.w
Postby ossie cossie » Sun Mar 06, 2016 5:26 am
awesome work Do the MK6 headlight wiring connector just plug straight into the MK 7 headlights. :)
ossie cossie
Postby jonochap » Sun Mar 06, 2016 9:11 am
Great read :)
jonochap
Postby paul2012 » Mon Mar 07, 2016 12:28 pm
ossie cossie wrote:awesome work Do the MK6 headlight wiring connector just plug straight into the MK 7 headlights. :)
Yes it plugs straight in.
Although I slight wiring mod for headlamp level & indicators in require.
On both headlight plugs Move GND from pin 1 to pin 5
Then add 12V+ from indicator to pin 1
paul2012
Postby BomberHarris69 » Sun Jan 22, 2017 11:27 pm
Hi Paul,
I'm about to undertake the same process to my mk6 transit van, could you please tell me all the item codes I will need to buy the correct parts from ford, also how much did you cut of the chassis legs? did you just cut level to the out side flange?
Thank you in advance for your help & input
Regards Neil
BomberHarris69
Postby paul2012 » Mon Jan 23, 2017 11:42 pm
BomberHarris69 wrote:Hi Paul,
Regards Neil
See my project thread here :arrow: viewtopic.php?f=27&t=150664&start=240#p1298704.
There you will find all info & Ford Part no's etc 8) :wink:
paul2012
Postby Charlienorris62 » Tue May 09, 2017 8:26 pm
Hi Paul,
Really love the work you carried out here.. I've been looking to do the conversion on mine and after seeing this thread its very helpful.
I am just very unsure in regards to cutting / welding the inner wings...
Would this be something you were willing to carry out for me or recommend anybody who could carry out these works if not??
I could supply all parts + sort out a price.
Charlie
Charlienorris62
Postby rhinocharge » Sun Mar 04, 2018 5:37 pm
Kudos to you Paul1 A very informative read along with dedicated work. 8)
rhinocharge
Postby Fabiantaylor » Tue Feb 12, 2019 11:40 pm
Hi would you have the reworked wiring diagram for the mk6 to mk7 indicator and wiper stalk please as just fitted all the dash in
Fabiantaylor
Postby Tranny mk6.5 » Sun May 26, 2019 3:20 pm
Hi there, im new here, im in the middle of swapping mk6 running gear etc to a mk7 transit, ive managed most of it but need some help with wiring on column switches please, ive tried clicking on your link but it says im not authorised to view :| cheers chris
Tranny mk6.5
Postby Troy123 » Thu Jun 13, 2019 12:05 am
Hi am in need of the same plz trying to wire up the stalks but mine are all numbers
No letters on them thabks
Troy123
Postby Alanbbb » Fri Jul 12, 2019 11:00 pm
Hi Paul hoping you could help me finish my conversion I've done everything already front end dash headlights light mod door mod for windows and central locking gears on dash I have done indicators so far need help with flashes and wipers can you email me a diagram at brightlad8@gmail.com thanks in advance
Alanbbb
