done some more the last week or so
inner sills shaped and cut to length, original flange for inner arch was reshaped and belted about with a hammer
inner arch was started, pool welded to inner sill for extra strength
new lower inner wing section made and welded in, upper reinforcement removed ready for new one, ordered from ford, waiting delivery.
Its fairly rusty behind here
So is closer to the front, thought id take a few pics to show how ive been replacing little bits here and there, ive wire wheeled it all
cut out the rotten bit
cut a patch to rough size
keep trimming until it fits and clamp it in place
tack weld one side and remove one clamp
finish tacking that side
tack weld one corner of other side and remove clamp
tack weld the rest of side whilst pushing the panel edges flush
wire brush the welds off
finish welding then grind flat, no need to go mad blending out, it will get burried under another panel soon
and another
rot cut out, all edges, and inners cleaned up as best as grinder and brushes can reach
given a coat of zinc primer then a repair piece cut out, 1.2mm zintec sheet was used
corners are marked then its put into the press brake ( homemade angle iron and a 20ton press)
and out pops a shaped repair piece
some last minute marking and cutting
and first side tacked in
pay attention here because i forgot to put holes in the panel where the original spot welds where, they had to be drilled with the panel in situ, very carefully as to not go through the one behind it too - they will just magically appear on next pic
told ya so! it been welded in too
and ground back, it should also be zinc primered but ive ran out
hopefully get some more done soon
