MK1: THE MOON ROOF
Re: MK1: THE MOON ROOF
Postby transitandy » Thu Dec 03, 2015 4:31 pm
Nice to put a face to a name :)
You'll have to come over next year in august for transitmania TM8 8)
Postby ilkeryesim » Thu Dec 03, 2015 8:32 pm
transitandy wrote:Nice to put a face to a name :)
:) :) we want to come there. if we can finish this (pancarvan), approximately 3000 km of road will be taken. it will be exciting travel, we 're dreaming this journey everyday. we didn't share it's completed design yet. it's very very nice, but there is more time to share it with you :) :)
ilkeryesim
Postby ilkeryesim » Mon Dec 14, 2015 4:28 pm
the second van's engine and transmission have been repaired and tried for their maintenance .the engine's intake manifold and double carburetor are as the same of ford granada and will be modified. hereby we hope a little increased performance
ilkeryesim
Postby transitandy » Tue Dec 15, 2015 12:58 am
Keep up the good work m8y :) 8)
Postby bezzabsa » Tue Dec 15, 2015 3:24 pm
we need Mk1's like that over here!!!
:shock:
Driving a Transit estate...Mondeo 130 Tdci 2002 ;)
Yam Yam from yamyam land ayit ??
Bostin' ay it?
bezzabsa
Postby ilkeryesim » Tue Dec 22, 2015 9:00 pm
We bring the van back to our garage again and now it is this van's turn to be dismantled.
ilkeryesim
Postby ilkeryesim » Tue Dec 22, 2015 9:07 pm
It is not difficult to rip or distribute, I don't know what will we do when we gather.
ilkeryesim
Postby ilkeryesim » Tue Dec 22, 2015 9:22 pm
we undercoated with polyester undercoating as a protection againist corrosion and resolving minor defects.it was used 3 liters but it was not enough. we will buy more 1 liter and apply to internal parts.
ilkeryesim
Postby transitandy » Thu Dec 24, 2015 12:06 am
Proper transit porn :D 8) 8) 8)
Postby ilkeryesim » Fri Jan 15, 2016 8:30 pm
Try to continue color painting the wheel, metalic red was not bad after purple but i think it will be finished with white painting
ilkeryesim
Postby ilkeryesim » Fri Jan 15, 2016 8:39 pm
ilkeryesim
Postby ilkeryesim » Fri Jan 15, 2016 8:48 pm
ilkeryesim
Postby ilkeryesim » Fri Jan 15, 2016 8:50 pm
we met with the new bodywork repairer named Özer, who can play on the body like dough. the left signal frame was not fitted into the recess, so he repaired it. headlight frames has been repaired. some minor corrosion on body and front panel mended too.
ilkeryesim
Postby ilkeryesim » Sat Feb 06, 2016 10:12 pm
22/12/2015
Doors were adjusted and delivered to the painter. Gaps on the hinges were fixed. body repairer was not freed easily. Escaper little things were solved. The tailboard was adjusted. By the way, I applied the insulating material to the internal parts of doors to not decay again. Also I made two hole in the undersides because of waterhole.
ilkeryesim
Postby ilkeryesim » Sat Feb 06, 2016 10:14 pm
24/12/2015
Doors are ready. The insulating material was applied to the bottom and steps. Internal parts of the doors were painted. It was excited to see the real color of the car for the first time.
ilkeryesim
