It has been an one owner vehicle from new and it has an respectable mileage: 674000 kilometres and it has it's original engine running! In last week the temperature was as low as -34 celcius, at Saturday it was only -12 degrees and the fired up immedeately after using glow plugs...
The body is in pretty good shape, the visible rust is mainly surface rust and cosmetic. But for the next MOT some welding is needed, the worst places are in the back section of the chassis rails. I dont't have any pictures from underneath the van, but I will take them when I have chance for it. Luckily it's not white, colour is Medium Steel Blue. Some pictures:
There are some alloys with, but they are in summer tyres:
And some surface rust:
Not so bad, when you think of age and mileage:
But there are some faults in it: error codes P0409 and P0404, which are from EGR? It seems that there is already a little ball bearing in the tube, but correct if I am wrong that EGR is not blocked off? The glow plug light flashes on, even if you empty the codes it comes right back. There was also code P0149, but it didn't show anymore after emptying. Van is struggling to get speed and rounds up, even 3000 rpm is hard to achieve.
What to do, take the EGR off and clean it (manifold also?), after that put a blanking plate on and everything should be working? Or what?! Thanks already!
