nedforceone in progress
Re: nedforceone in progress
Postby ned » Sun Aug 20, 2017 5:20 pm
Yes I have tidied out the van but it looks no bloody different :lol: 6 bin bags full or was it 8 of crap for the tip, the younger two cleaned the van and my eldest polished half the van :roll: N
03 transit 125t280 2.0 tdci swb executive college blue 92 crewcab. Built in Belgium so deserves lots of love. 213,000 miles on the clock.
Instructions for use. fill with fuel. start engine. drive like a t#@t.
ned
Postby dirtydog » Sun Aug 20, 2017 6:39 pm
Hahaha I have to completely empty mine out when it goes in for repair :x
2006 Mk7 115 350
dirtydog
Postby ned » Wed Aug 23, 2017 5:17 pm
Had a busy day today, been to the junkyard and got injector leak back pipe, injector/rocker cover seals and a pas/water pump belt cover
Then the injector overhaul started with the help of a vice
Removed the tip, sprayed cleaner through the nozzle and swapped the control bits over with the new ones (I did 1 injector at a time and put it back in)
All 4 done, cleaned and back in the van
Now it wont bloody start, got fuel to all 4 injectors, fuel filter is full so I have either done something wrong or broke my van, trouble is my son moved the injectors with my valve things in and now I don't know which one was for each injector :roll: Bloody typical, bloody ford. N
ned
Postby bigjohnthomas » Wed Aug 23, 2017 5:24 pm
PhwOOOORRRRwwwwwwOOOOOOOrr love that vice 8)
They call me Mr Bum Drastic
bigjohnthomas
Postby ned » Wed Aug 23, 2017 5:28 pm
25 sovs bargain :D from the local tools place. N
ned
Postby ned » Fri Aug 25, 2017 2:18 pm
Split the headlights and gave them a good clean in and out, also added some red LEDs (for show only)
ned
Postby ned » Fri Aug 25, 2017 8:11 pm
Scrubs up well, washed and polished while charging the battery, also cleaned where the headlights go
ned
Postby karl » Sat Aug 26, 2017 12:21 am
so is it running now :roll:
karl
Tranny Lover!!!
Postby ned » Sat Aug 26, 2017 8:36 am
karl wrote:so is it running now :roll:
It was but I had a leak and now its not starting again, think I have an air in the system. N
ned
Postby bambi mk 1 » Sun Aug 27, 2017 1:45 pm
Need to do a bit of badge engineering when you get it sorted Ned :)
Image You could let it be your badge of honour :lol:
Just pray its not this one you end up with
Theres the good guys,theres the bad guys but there only ever be one SPEED GUY
bambi mk 1
Postby ned » Tue Sep 26, 2017 7:39 pm
Now its back up and running I can carry on with the modification :D
First priority is to get the bloody wheels balanced, it shakes like a shitting dog at 50 - 60 mph :lol:
Need to stick a post it note on the windscreen to remind me I have another gear, 5th :shock:
Now I have my vice I might change the drivers side front wheel bearing,
passenger side rear wheel bearing and passenger side front abs sensor both need replacing
I have been looking at that vinyl wrap stuff for the blue parts of the dash and maybe the carbon fibre effect stuff for the door cards, is it easy to use.
ned
Postby loot » Tue Sep 26, 2017 10:43 pm
It goes on nicely then when the temperature changes is goes shit and any convex shapes you did it stretches and looks shite:-( that's the 2d 5m for 15 pounds stuff tho Lol.
3d or 4d might need more heat?
Ids map here
loot
Postby bigjohnthomas » Wed Sep 27, 2017 9:11 am
I have yet to witness a dog shake when it shits :?
bigjohnthomas
Postby ned » Wed Sep 27, 2017 7:17 pm
loot wrote:It goes on nicely then when the temperature changes is goes shit and any convex shapes you did it stretches and looks shite:-( that's the 2d 5m for 15 pounds stuff tho Lol.
I have been looking at the 3D stuff, don't know what the bloody difference is though, I'll have to order some at 3am when I cant sleep :lol: Where do you purchase the 2D stuff that'll do for the door cards. N
ned
Postby ned » Wed Sep 27, 2017 7:23 pm
bigjohnthomas wrote:I have yet to witness a dog shake when it shits :?
Funny enough I have never witnessed that either, its one of them saying my dad used to say along with,
Its as long as it is broad,
Stop crying or I'll give you something to cry for,
Ask your mother,
Av you got my psv badge again,
And my favourite,
Who the f*** gave the dog sprouts :lol: N
ned
