Soon to be camper/dayvan :)
Postby mattt429 » Sun Jun 19, 2016 6:27 pm
Picked up a mwb (mk6?) 100k with MOT till September. Started getting her ready for test.
So far have fixed:-
Propshaft bearing/joint
Re wired half the dashboard as nothing seemed to work.
Next up im cleaning up the chassis to get some welding done then underseal the lot with tetroseal :)
Thought id stick some pics up, lots more to come soon as this cornish weather makes up its mind haha!
Heres some rust p*rn ;)
Sent from my GT-I9300 using Tapatalk
2003 MK6 T350 90PS 2.4 TDDI MWB MHR RWD
mattt429
Re: Soon to be camper/dayvan :)
Postby mattt429 » Sun Jun 19, 2016 8:19 pm
Ok so here was the knackered propshaft bearing
Here is some chassis I found
More pics to come, vac pumps leaking a good un so will have some more oil covered pics ;)
mattt429
Postby mattt429 » Tue Jun 21, 2016 12:22 am
After spending mpst of today turning the offsode chassic from rust to chrome ;)
ive applied the first coat of tetroseal. I didnt heat it first as many have done as I found its consistency perfect for ramming into all the nooks and crannies, with a cheapo wilko brush.
Heres the offside nearly complete and ready for underseal
Will take some pics tomorrow before applying second coat.
Then I need to make a start on the drivers side as I have found some rot which will need welding or cutting out. Happy times!!
mattt429
Postby mattt429 » Tue Jun 21, 2016 3:56 pm
First coat of underseal
Second coat on and drying :)
mattt429
Postby mattt429 » Wed Jul 20, 2016 8:16 pm
So the last few weeks have been pretty hectic but managed to fix the ABS and have done a bit more work with the chassis:-
2nd coat of underseal dried and looking good.
Some more chassis cleaned up:-
Getting there slowly, the back end looks pretty rotten out so will probably require quite a bit of welding :/
mattt429
Postby ned » Wed Jul 20, 2016 9:25 pm
That's not rot its just surface rust where was your van built.
Looks too clean for a Southampton van. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby mattt429 » Thu Jul 21, 2016 9:24 am
The back end is flaking quite badly lol ill get some poctures for you. She is a Southampton build, but your right its quite clean underneath. Think the build up of mud helps!
mattt429
Postby transitandy » Thu Jul 21, 2016 12:57 pm
Nice work m8y :)
I must get round to doing mine :P
Postby mattt429 » Thu Jul 21, 2016 7:55 pm
Cheers guys, im alsp in the middle of rebuilding a house so time for the van is something I dont have a lot of haha. :(
My step dad is going to do the welding for me, which is awesome as at the end of it I will own a welder and have a year to practice techniques before next years MOT :-)
More pics coming soon :-)
mattt429
Postby mattt429 » Tue Aug 30, 2016 9:18 pm
So the last couple of weeks have been absolutely manic!
However i decided to pick up a mig 140 welder and take a hammer to all loose chassis parts :D :D
The result:-
Shaped up some 1.6mm and stuck a few bits back together
The driver side sill was pretty rotten, a big repair.
Made up some box section for the passenger side middle sections and one on the rear next to the spring hangar.
mattt429
Postby mattt429 » Tue Aug 30, 2016 9:21 pm
Some plates seamed up :)
mattt429
Postby mattt429 » Tue Aug 30, 2016 9:24 pm
I then ripped out the flooring as i could see ply from both rear wheel arches! :)
So thats the arches and floor sorted, seal the lot tomorrow and then off to MOT thursday for hopefully, just a set of tyres :)
mattt429
Postby mattt429 » Fri Sep 02, 2016 7:40 pm
Failed mot yesterday:-
Brake pads
Brake lines
Handbrake efficiency
Tyres
Ball joint
Track rod end
Hole in passenger side upper arch (swine)
Number plate lights not working (surprise surprise fine outside the test centre -_- )
Soooo....
mattt429
Postby mattt429 » Tue Nov 01, 2016 11:56 pm
Once again things are as hectic as always, however ive been at it like a headless chicken and things are really starting to take form :)
Managed to get her through MOT. Took quite a bit of work but i think it was worth it as she drives like a dream and returns 25-30mpg, depending wether the wife is in the passenger seat or not :wink:
Insulated the floor and put some carpet down, only cheapo but it will do for now. I'm sure er indoors will cover the place in 'orrible lady stuff.
Also removed the existing ply lining and insulated behind their too :)
El cheapo base unit from Wickes with some 12.5mm ply for a worktop, insert power tools and a brew...
The bed frame is made of 2 x 4, wife is a big lass :) just a simple frame with 5.5mm ply screwed to the top.
I ended up adding a middle support to the bed, but i haven't got a picture of that yet.
With some remaining plywood i easily made some doors for the storage under the bed. Again cheap and cheerful but they seem to work for now.
The base unit has now had its legs removed, as im 5ft 9" i was a bit hunched using the worktop.
Proof that women can't leave anything alone ^.^ :)
More pics to come as everything's had a good clean...
mattt429
Postby mattt429 » Wed Jun 07, 2017 7:39 pm
Thought its about time for an update, finished up all welding and undersealing. :-) have spent a fair bit of time sorting the van out :)
Made up new bench seat/bed frames with lift up lids
Then panelled everything in and made up the folding table/bed middle
mattt429
