rimotu66 wrote:Can you put a pic up with what you need machining off? How quick do you need it done?
Ah i sense an offer? Which is appreciated but i think it's OK now, if you look at the image, the right edge has hit the chassis leg and squashed against the next lip in, in places, this trapped the belt causing it to basically wander off the wheel a tooth and scrub on the chassis which sounded god awful, also since i ran the engine without any belts on or crank pulleys and woody woodpecker was still there i conclude that the pulley is fine.
Incidentally, when the engine is hot and I'm in 6th doing 70ish you cannot hear the engine tapping at all, only when accelerating and very loud at cold so I'm thinking 90% injectors
Anyway, if it changes i might take you up on that but i have 'a guy' 5 mins away in fairness
Once i get the ac system repaired and refilled i can put the plastics back on and sort it out then take it to Ford.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
07 350 170ps
Ids v86 licence + v86.04 update + xprog
hereIds map
here
