Loots Red custom
Re: Loots Red custom
Postby loot » Mon Jan 08, 2018 5:37 pm
Found my elm 327 Bluetooth so downloaded forscan demo and it linked up :-)
Mine doesn't have the switch for hs and ms but according to Google if it asks if i have a switch then my elm is capable of running it if i add the switch (don't make sense to me like but I'll play along :-),)
Thought I'd look at my boost levels.
Hmm interesting, from the graph it appears to measure boost and vacuum(50% positive/negative state rather than 0 boost to 100%) or its it wrong? :?
This is the actual boost pid.
07 350 170ps
Ids map here
loot
Postby froggie11 » Sun Feb 25, 2018 1:19 am
hi
where abouts does the cap connect to on the relay ?
cheers Dave
froggie11
Postby loot » Sun Mar 04, 2018 10:27 pm
viewtopic.php?f=27&t=172399&hilit=Electric+folding+mirrors&start=885#p1527864
Either side of the coil side of the relay.
I think. Bjt smaller relay works without the capacitor and resistors which would seem simpler tbh.
I'm sure he'll have a full how to somewhere :mrgreen:
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Mon Mar 05, 2018 12:23 am
I've noted that my drivers side mirror has started going grrrrreeeaarrrrrrrrrkkkk when it winds in sometimes
Not sure if the FORD TRANSIT mirrors can cope with all this folding and unfolding
Bloody ford
bigjohnthomas
Postby loot » Mon Mar 05, 2018 9:14 am
Maybe the relay is stuttering?
It is a possibility that Ford decided that folding should be restricted to 2 times in 10 years?
Mine are fine though :-)
So you have broken mirrors because you wind them too much or you have broken mirrors because some t**t smashed them off trying to get passed.
Can't get a break can we :x
Maybe yours are just frozen up?
07 350 170ps
Ids map here
loot
Postby loot » Tue Mar 20, 2018 12:27 am
Ordered 2 door handle recesses for red, fed up with not being able to grab them :x
These are from Hong Kong and are just generic plastic things :lol:
What could go wrong? :P
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Tue Mar 20, 2018 11:31 am
wheres that go then :?: :?
bigjohnthomas
Postby loot » Tue Mar 20, 2018 12:43 pm
Now come on bjt you know perfectly well where it goes :P I've bought 2 8)
I will no longer be nervous about a blow job :lol:
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Tue Mar 20, 2018 2:09 pm
:? in the top of the door trim? like a tramps van?
your going to cut ahole in it?
bigjohnthomas
Postby loot » Tue Mar 20, 2018 3:05 pm
Too right I am and I'll bodge it and it'll look sh*t but at least the wing won't get bent :P
Anyway........
https://m.ebay.co.uk/itm/2017-Ford-Tran ... 5232.l9681
Only took them 4.5 years to remedy it :lol:
07 350 170ps
Ids map here
loot
Postby loot » Tue Mar 27, 2018 10:33 pm
Eyed it up what do you think chaps? Dogs toffee or dogs nuts? :P
It isn't lined up and is just sat on top, I'll maybe trim it and then fit it in the hole.
07 350 170ps
Ids map here
loot
Postby loot » Thu Mar 29, 2018 2:50 pm
Drivers side, still wants flushing up but it isn't going anywhere and I won't worry about a gust of wind taking it :evil: :?
07 350 170ps
Ids map here
loot
Postby ned » Thu Mar 29, 2018 5:44 pm
Nice little ashtray you've fitted there :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby bulls in transit » Thu Mar 29, 2018 6:54 pm
loot wrote:Drivers side, still wants flushing up but it isn't going anywhere and I won't worry about a gust of wind taking it :evil: :?
Lot more professional than Fords original ‘fix’
bulls in transit
Postby loot » Thu Mar 29, 2018 8:52 pm
:lol:
Can't argue with that :-)
07 350 170ps
Ids map here
loot
