Loots Red custom
Re: Loots Red custom
Postby loot » Fri Mar 31, 2017 7:52 pm
Not on tickoveri can't do it, but when under load it knocks/taps at certain revs, on rare occasions it disappears and i think the engine has stopped, i think the engine should be quiet all of the time tho.
And it is 1 knock/tap as in 1 of 4 if it is an injector or rocker.
Tickover
Driving
https://youtu.be/k3brKBcF3A0
More driving
https://youtu.be/WConUY_yFKA
Bloody ford
My mk6 90ps tddi was quieter :lol:
Ids map here
loot
Rem: Loots Red custom
Postby bigjohnthomas » Fri Mar 31, 2017 8:05 pm
That sounds like sooty :P
By ehk mines nought like that
And the highly trained ford engineer said its all good ? Perfect ? El torro?
Bloody ford
bigjohnthomas
Postby loot » Fri Mar 31, 2017 8:48 pm
Any chance of a video of yours when your driving? Your custom that is :lol:
Ids map here
loot
Postby karl » Fri Mar 31, 2017 9:04 pm
I have a video on my work page of ~ noisy euro 5 without the mufflers on or are the injectors :D
karl
Tranny Lover!!!
Postby loot » Fri Mar 31, 2017 9:07 pm
karl wrote:I have a video on my work page of ~ noisy euro 5 without the mufflers on or are the injectors :D
Have you got a link? :D
Ids map here
loot
Postby bigjohnthomas » Fri Mar 31, 2017 9:37 pm
loot wrote:Any chance of a video of yours when your driving? Your custom that is :lol:
Yes I make one ..but its all clean and filled up ready to go to Weston super mare for the show on Sunday so I am not allowed to mess with it till it gets back :x I'll do it on Monday
This will do till then :P
https://youtu.be/hQsfSu2egTg
bigjohnthomas
Postby loot » Fri Mar 31, 2017 9:55 pm
Cor how is it so smooth?
Ids map here
loot
Postby bigjohnthomas » Fri Mar 31, 2017 10:07 pm
:lol: well it has 4 separate injection pumps
Modular engine init you can get it in 2,3,4and 6 cylinder
Just keep weldin pots on the end :lol:
Bloody Italians
bigjohnthomas
Postby loot » Fri Mar 31, 2017 10:23 pm
Like ford 3.2? Extra piston to break :lol:
Ids map here
loot
Postby bigjohnthomas » Fri Mar 31, 2017 10:40 pm
That's easy with common Rail just a few more wires n stuff no expensive five pot injection pump to make .....
Back in the days when men were men and sooty vans and ruled the earth
bigjohnthomas
Postby bigjohnthomas » Sat Apr 01, 2017 12:05 pm
Just sneeked it out and made a vid
But its rubbish and you can't hear pinky n perky :x
I'll try again Monday
Stick phone out of the window mayhaps :?https://youtu.be/1zScDZiVAQQ
And put the seat bet on :lol:
bigjohnthomas
Postby loot » Sat Apr 01, 2017 12:40 pm
Yes seatbelt lol, sounds very smooth and quiet, mine was with the windows closed etc and noisy as fook, got mused post which i think was the injector which will be Monday i think.
Ids map here
loot
Postby loot » Fri Apr 07, 2017 11:02 am
Fitted the new passenger wiper motor and adjusted it so now it isn't fouling the end of the screen and the bonnet 8)
Weekend of truth I'm going to fit the injector i bought for 45 pounds :shock:
Bloody ford :lol:
Ids map here
loot
Postby loot » Sat Apr 08, 2017 3:20 pm
I've been all through ids and on live data and can't see anything relevant to manually learning injectors and typical Ford,.
Bit like the dealers eh :lol:
And i then swapped number 1 injector over and put it's correction factors in but alas it didn't evict woody, 3 more to try.
I have a feeling i should remove all 4 and the rocker cover to check the moving bits up there before swapping injectors over.
Ids map here
loot
Postby loot » Sat Apr 08, 2017 4:36 pm
Put the 45 pounds injector into cylinder 2 and coded it in, where's woody gone? There's no singular knocking evident, still a gruff when you accelerate but really different now.
Will have to leave it there till morning when the engine is cold, haven't done any resets or anything but it sounds promising, what next tho? Put number 2 back in then back to ford, hey Pedro check all 4 injectors and replace any fooked ones?
Ids map here
loot
