Loots Red custom
Re: Loots Red custom
Postby loot » Wed Jul 12, 2017 5:35 pm
Long story but i went to Ford and they said no way man we can't fix that for less than 5k.
:shock:
So a friend of mine said try nick at vauxhall take some hobnobs, well that sounds like my kind of fellow 8)
288 dollars and 2 days and It's done.:-)
87(ish)pounds was materials, 48(ish)vat and the rest labour , not bad considering the wing was scratched to fook.
Ids map here
loot
Postby bigjohnthomas » Wed Jul 12, 2017 5:41 pm
8) sounds like a good price
hobnobs eh? it used to be a packet of fags when i was a kid
its about time hobnobs had pictures of shrivelled up peniss and stuff on them like fag packets have too
all that sugar, where they chocolate ones too :P
They call me Mr Bum Drastic
bigjohnthomas
Postby loot » Wed Jul 12, 2017 5:48 pm
No he refused blank so i sat on the curb outside eating them and crying :lol:
It's a good price, although you'd think by now they'd be able to match the colour :roll:
Yes mr loot i have to spray the wing but then i have to spray the corner of the bumper then the front of the door then i have to lacquer the whole van :shock:
But still it'll do. 25k van there for 12k +my labour. :mrgreen:
Ids map here
loot
Postby neill » Sat Oct 07, 2017 3:49 pm
Hi loots . I'm trying to do the very neat modification you did on auto closing on the power mirrors . I've got them closing fine when I double lock but I'm not getting a positive pulse from wire 3 on the actuator so the mirrors will not open when unlocking.
Any chance of looking at my wiring diagram to see wher I went wrong?
neill
Postby bigjohnthomas » Sat Oct 07, 2017 4:04 pm
Loots busy running up a hill right now
I may be able to help
I don't remember having an earth involved
bigjohnthomas
Postby bigjohnthomas » Sat Oct 07, 2017 4:07 pm
This is what I have in my engineering book
bigjohnthomas
Postby neill » Sat Oct 07, 2017 4:19 pm
Can't really understand your notes . Wire 3 from the actuator produces a pulse to the relay upon locking but nothing when you unlock
neill
Postby bigjohnthomas » Sat Oct 07, 2017 4:22 pm
That make 2 of us :lol:
Are you using an automotive relay ?
I used a reed relay on mine
Loot had to put a cap in to make his big relay work
I don't think there's quite enough of a pulse for a big relay
bigjohnthomas
Postby bigjohnthomas » Sat Oct 07, 2017 4:30 pm
Pin 4 and 8 to relay output
You have them wired together and an extra earth
Put one one side and one the other of the switched relay output
That I believe is the problem :P
bigjohnthomas
Postby neill » Sat Oct 07, 2017 5:48 pm
bigjohnthomas wrote:Pin 4 and 8 to relay output
Pin 8 is just an earth anyway , so rather than use 8 I just used the earth. The problem is on the other side of the relay , pin 3 is only sending a positive pulse on the locking motion , this correctly closes the relay and in turn closes the mirrors. The problem is that the pin 3 does nothing's nothing when the van is unlocking so the mirrors don't recieve the earth signal to open.
I'm a domestic sparky so have a reasonable understanding of these things, but the wiring config as loot explained it does not appear to be working , he wired it correctly but I don't understand his explanation
neill
Postby bigjohnthomas » Sat Oct 07, 2017 6:04 pm
No earth
Pin 3 runs through the relay cut the wire going to it one end one side and the other the side of the relay
There you see I remembered in the end :P
Just get rid of that earth
bigjohnthomas
Postby bigjohnthomas » Sat Oct 07, 2017 6:06 pm
Loots actually an algorithm so sometimes its difficult for us humans to tell what he's going on about :wink:
bigjohnthomas
Postby bigjohnthomas » Sat Oct 07, 2017 6:13 pm
Thats it isnt it?
Have you done it yet? :P
bigjohnthomas
Postby neill » Sat Oct 07, 2017 6:25 pm
bigjohnthomas wrote:No earth
Ok thanks , I will try that tomorrow . Just couldn't understand that if you cut the wire from pin 3 , then the actuator loses it signal to lock
neill
Postby bambi mk 1 » Sat Oct 07, 2017 7:26 pm
Heres one Loot and BJT prepared earlier .
http://i.dailymail.co.uk/i/pix/2014/11/ ... _Rothe.jpg
Theres the good guys,theres the bad guys but there only ever be one SPEED GUY
bambi mk 1
