Back with a mk7 this time!
Re: Back with a mk7 this time!
Postby ned » Wed Aug 31, 2016 10:35 pm
Have you given the van a name yet :D (or shall I say have the kids named it). N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby dirtydog » Wed Aug 31, 2016 10:47 pm
Got some work done on the floor over the past few days as well.
Did the front section first
Gave it day to dry properly then shifted my tools and crap up front and this afternoon I started on the back section
Angle grinder with a flap disc made short work of the loose paint and surface rust and then slapped a bit of rust converter about
Gave that a few hours to do its thing and then gave it a good coat of red oxide
This picture was actually taken at about 930 when it was dark, 2 led strip lights are enough to light up all of the back, I've got another 2 of the strip lights in the garage so might fit them as well :shock:
And no they haven't named the van yet which is unusual for them :roll:
dirtydog
Postby dirtydog » Sun Sep 04, 2016 10:48 pm
Got back from Wales at 6 this evening, sorted house stuff and sorted food for the dog and children and then went out to finish the floor
Ran out of blue so had to do the last bit in black :roll:
dirtydog
Postby transitandy » Sun Sep 04, 2016 11:36 pm
Your doing a good job there :)
Postby dirtydog » Sun Sep 04, 2016 11:41 pm
Thanks, doing what I can with the budget I have
dirtydog
Postby blue estate » Sun Sep 04, 2016 11:46 pm
Looking good
72plt MG 5 ev estate Battery car
blue estate
Postby dirtydog » Tue Sep 06, 2016 7:22 pm
Received a new side door lower roller and rear door lower catch in the post this morning so got the rear door catch fitted. Found the cable, plug and broken bulb in the bottom of the door from the brake light so need to sort that as well now but couldn't find anything to shove down through the door to pull the cable back up.
Found the tow bar is wired in with scotchlocks, but also another plug that I think is for reversing sensors
Plug behind drivers side rear light
Old door catch which was swished and the new one
dirtydog
Postby dirtydog » Wed Dec 28, 2016 9:44 pm
Not done a great deal other than drive it.
Leak off test done today
Injectors 2 isn't great but 4 is definitely knackered
Inlet manifold removed and cleaned, forgot the before picture but to be honest it wasn't too bad
dirtydog
Postby dirtydog » Sun Feb 05, 2017 11:36 pm
Replaced the front interior cab light with one from a Mondeo, much brighter and the map lights are useful.
Also bought some ply to finish off the floor
dirtydog
Postby Sjjohno » Tue Feb 21, 2017 10:53 pm
dirtydog wrote:Replaced the front interior cab light with one from a Mondeo, much brighter and the map lights are useful.
These just a case of cutting head lining and connecting the wires?
Any photos of the wires behind ? Or to simple for photos?
Sjjohno
Postby dirtydog » Wed Feb 22, 2017 6:04 pm
Yeah just a case of cutting the headlining. I held the light fixing ring in place and drew around the inside of it, cut it out with a Stanley knife.
Wiring is straight forward, 3 short bits of wire with a male spade at one end and female at the other end to connect the light to the original wiring or you can cut the original connectors off and replace with female spades
dirtydog
Postby Sjjohno » Wed Feb 22, 2017 8:17 pm
dirtydog wrote:Yeah just a case of cutting the headlining. I held the light fixing ring in place and drew around the inside of it, cut it out with a Stanley knife.
Thanks like the look of that
It's now on my list ha
Sjjohno
Postby dirtydog » Wed Apr 12, 2017 11:32 pm
Not much done recently due to lack of time but got my reversing camera monitor fitted
Used the monitor that I already had, couple of m6 bolts, couple of 25mm threaded balls, bit of timber and a ram mount connector
Just need to fit my camera now :roll:
dirtydog
Postby dirtydog » Sat Jul 01, 2017 10:15 pm
Wiring loom repaired properly, was causing all kinds of electrical odd goings on
Had a leak from the turbo oil feed pipe, got new washers to fit and then found it's actually the fitting on the end of the pipe
There goes £110 at the dealers :x
dirtydog
Postby dirtydog » Thu Jul 27, 2017 12:49 am
Oil feed pipe to the turbo replaced, was a pig of a job involving taking the aux belt off, alternator off then the big bracket thats attached to the side of the engine that holds the alternator and ps pump
New pipe fitted
dirtydog
