Back with a mk7 this time!
Re: Back with a mk7 this time!
Postby ned » Fri Apr 06, 2018 8:45 pm
You could have stored the steelies on my van :wink: I need three new ditchfinders as mine are abit kojac :oops: :lol: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby dirtydog » Fri Apr 06, 2018 8:56 pm
I actually have 3 tyres with good tread, I wouldn't say they were good tyres though :wink:
dirtydog
Postby ned » Fri Apr 06, 2018 9:09 pm
The best tyre on my van is a kingpin remold :shock: :lol: 4 new ditchfinders on eBay 140 sovs delivered :? N
ned
Postby squirrel93 » Fri Apr 06, 2018 11:15 pm
ned wrote:The best tyre on my van is a kingpin remold :shock: :lol: 4 new ditchfinders on eBay 140 sovs delivered :? N
I had these on the lwb for 2 years and lasted well I replaced them with the same company again and the balance was terrible! The machine wouldn’t weight them out was like I had square wheels when I got onto the motorway , I sold them on and learnt my lesson to pay the extra they were seriously dangerous
squirrel93
Postby ned » Fri Apr 06, 2018 11:26 pm
Aye it was the only one I could get when the gt radial did a punto :wink: 35 sovs fitted :shock: says it all. N
ned
Postby squirrel93 » Fri Apr 06, 2018 11:29 pm
The tyres were good lasted around 40k on the RWD sure they were 225/75/16s , it was once I replaced they were bad quality maybe a bad batch?
squirrel93
Postby dirtydog » Sat Jun 16, 2018 2:00 pm
A few jobs ticked off the list this week, egr valve replaced, new glowplugs fitted, a track rod end and front passenger side brake line replaced with a new copper one.
New egr went in relatively easily unfortunately the old one didn't want to come out and put up a good fight, egr ended up looking like this...
And I ended up with a bit of a black eye
Glowplugs came out nice and easy too especially with the inlet manifold out of the way
Hopefully that will sort the starting issues I have when it gets cold
Track rod end was advisory on the last mot as having a bit of play, wasn't too bad when I took it off but cheap enough to replace
Front brake lines were also advisories last year as being corroded, drivers side was replaced as it actually holed through, passenger side one broke as I was taking it off
Now for the first time since I've owned this van I have no warning lights on the dash (egr has been stuck closed since I bought it)
MOT next week
dirtydog
Postby bambi mk 1 » Sat Jun 16, 2018 2:35 pm
dirtydog wrote:A few jobs ticked off the list this week, egr valve replaced, new glowplugs fitted, a track rod end and front passenger side brake line replaced with a new copper one.
MOT next week and possibily another black eye but it wont be mine :wink:
FIFY :mrgreen: :P
bambi mk 1
Postby dirtydog » Wed Jun 20, 2018 7:20 pm
New mot today, advisories for front tyres close to limit and front brake discs worn.
Next job on the list is replacing 2 injectors
dirtydog
Postby dirtydog » Sat Jun 23, 2018 7:13 pm
Well I finally took the plunge and fitted 2 new recon injectors today and then plugged in my elm327 and forscan to do the pump learn and injector pilot learn
Slightly nerve racking as I've never really used forscan etc before but it all went well
dirtydog
Postby loot » Sat Jun 23, 2018 8:39 pm
8)
Ids map here
loot
Postby dirtydog » Sun Jun 24, 2018 2:28 pm
So next jobs on the list are the side door middle roller and new track and then oil sump as I still haven't replaced that yet either.
After I replaced the front brake pipe the other day and bled it all through (almost 2 litres through all calipers) the fluid that came out looked pretty murky
After a couple of days it had cleared a bit and a load of stuff had settled to the bottom of the bottle
No idea what it I said but it looks pretty grim
dirtydog
Postby blue estate » Sun Jun 24, 2018 2:48 pm
dirtydog wrote:So next jobs on the list are the side door middle roller and new track and then oil sump as I still haven't replaced that yet either.
That will be the insides of your brake pipes :shock:
72plt MG 5 ev estate Battery car
blue estate
Postby dirtydog » Sun Jun 24, 2018 4:49 pm
That's what I was thinking it might be, the pipes from the master cylinder to abs unit have been replaced, both front ones have been replaced and the front to rear are looking a bit worse for wear so I'll change them soon as well then do a lot of brake bleeding.
dirtydog
Postby vmaxman66 » Sun Jun 24, 2018 9:34 pm
Hello just reading through your thread.I no its not good when you have a bump in your van, but it looked nice and smart with a new front on
vmaxman66
