Is this exhausts diameter much bigger than what is fitted? Have you spoken to puma engineers to find out the flow rate required to allow the correct back pressure? Have you informed your insurance and dvla? Is there a fire extinguisher bolted close by with a safety certificate and do you have the correct fire training to use it?
Will the emissions decrease the fuel economy and efficiency of the diesel particulate systems? Have you informed the relevant government bodies about this? Is the exhaust type approved for use on public roads?
There's a lot more to it these days you can't just weld something on and away you go.
I think I've solved the mirror conundrum and it may just be 1 solitary relay required, done some tests but need a few more.
That's when i inform the right............
And acquire the right..........
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
Ids v86 licence + v86.04 update + xprog
hereIds map
here
