MK6 Transit Family Hauler.
Re: MK6 Transit Family Hauler.
Postby Quebulas » Mon Feb 20, 2017 8:53 pm
I'm hoping so. Still a way off from being ready for it's MOT.
Quebulas
Postby rimotu66 » Mon Feb 20, 2017 9:39 pm
Quebulas wrote:I'm hoping so. Still a way off from being ready for it's MOT.
The nights are getting shorter and its getting warmer so crack on :D
2007 SWB 110PS GLX Mk7
rimotu66
Postby Brains_transit » Mon Feb 20, 2017 9:53 pm
All those bits are the common areas and when you go looking for rust on a mk6 you end up fabricating up loads. Good work so far. I bought some bits and made others and also chopped the bits from mk7's in the breakers
Brains_transit
Postby Quebulas » Wed Feb 22, 2017 9:03 pm
I've not bothered looking about in the scrappers yet. There was a bloke local to me that was breaking one on eBay but everything I asked for he said was rotten.
I did a bit more to my van today. It's a bit tedious grinding in a shared car park when it's blowing a gale. I'm not even supposed to be using the car park as it's for the houses behind me but our lasses mother lives in one so... sod anyone who complains.
Here's what I did today. I stripped the rot from the drivers side wheel arch and fabricated a new piece to slot on.
I will wait for Doris to blow over before doing anymore work on it. :D
Quebulas
Postby grumpygramps-2007 » Thu Feb 23, 2017 11:45 am
keep the pics coming fella. as a newbie to welding my self found the way you made those panels in pieces first before welding very interesting. watched loads of stuff on utube but they often don,t show how the made the repair piece before welding it up. gramps.
grumpygramps-2007
Postby Quebulas » Thu Feb 23, 2017 1:01 pm
I'll try. Sometimes my hands are a bit too dirty to mess about with my phone.
Quebulas
Postby stevo » Thu Feb 23, 2017 4:34 pm
Cracking job there mate, mk6 vans rust everywhere so its gonna keep you busy. Whats the inner sills like? Theyre normally mostly disintegrated on a mk6 of that age, also the front wings, inner and outer
Sent from my HTC One_M8 using Tapatalk
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
Postby rimotu66 » Thu Feb 23, 2017 4:43 pm
stevo wrote:Cracking job there mate, mk6 vans rust everywhere so its gonna keep you busy. Whats the inner sills like? Theyre normally mostly disintegrated on a mk6 of that age, also the front wings, inner and outer
Yeah that's right, cheer him up why don't you :lol: :lol: :lol:
rimotu66
Postby Quebulas » Thu Feb 23, 2017 9:12 pm
The passenger side was ok. The underside of the outer sill had a 10 inch by 2 inch hole in it. The drivers side looks ropy as hell on the outside but not rotted through but the inside has a fairly large hole that I'll be tackling after this arch is finished.
Quebulas
Postby Quebulas » Wed Mar 01, 2017 7:12 pm
I finished the other wheel arch today. The rear of the van is now fully welded! :D
I just have the drivers side inner sill and inner wing left to weld. I want to go over the inner arches with white Hammerite to give it a little extra protection and to make it look better.
This is the piece I made up the other day. It fitted a lot better than the one on the other side.
My welding still isn't great but it's strong enough.
I coated this side in panel sealer. I have loads and I just thought sod it and went over it all. I'm not sure if that's gonna enough protection but it seems a lot better than the underseal that I have.
I like the finish of this seam sealer so I think I'll do all the other arches in this and go over it all with Hammerite.
Quebulas
Postby Quebulas » Fri Mar 03, 2017 6:16 pm
Had a nosy about the scrappers today and bagged myself a wing and some glossy scuttle panel covers and side bits. I also noticed my dash insert was broken so I got one of those along with the rear interior lights and a wheel brace.
I wanted to get loads of stuff but it started pouring it down and the van was in a deep muddy puddle and I started feeling fed up after getting the wing off.
I've seen some seats I want. Does anyone know what work is involved in fitting Mk4 Mondeo Titanium X seats in a MK6 Transit?
Quebulas
Postby Quebulas » Mon Mar 06, 2017 5:29 pm
The wing I bought was a bit worse than I first thought. I just decided to repair it and use it for now as it's in far better condition than the one fitted and, I wanted a little bit of practice with bodywork before tackling some of the other issues on my van.
Quebulas
Postby Quebulas » Mon Mar 06, 2017 5:34 pm
Other than the run, I think the painting came out ok. Once I've sorted the run out and it's flatted and buffed, I think it will leave a decent finish.
Quebulas
Postby Quebulas » Tue Mar 07, 2017 7:19 pm
Today I did the drivers side inner wing and inner arch. It's not the prettiest of jobs but it'll do. ImageImageImageImageImage
Just one small strip on the inner sill left to do then that's it for the welding.
Sent from my SM-G935F using Tapatalk
Quebulas
Postby ned » Tue Mar 07, 2017 7:29 pm
Jebus that's some rust :shock: Hope mine ain't that bad :wink: Thought you would have welded the front wing instead of fibreglass, look all right though.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
