Collected by a French mate from Auxerre
this is French roadlegal -on a Carte grise 'collection' (essentially you can drive anywhere in your local or adjacent County- but no more MOT's!
Delivered yesterday
running on 2 cylinders- quickly sorted with a new set of plugs etc.
I ripped the 3 beds off (2 steel & 1 original rotten wood) to discover a chassis in reasonable nick
-although there will be a bit of welding needed underneath.
Moving inside to the floor[img]
reveals plates welded and pop rivetted to plates- with a BIG hole underneath. passenger side looks worse -but the upside is that the outriggers still seem to be there- and patchable.
The engine seems OK
if a little smoky -but I think this'll clear once its used to running on 4. Its not a heavy breather and it sounds OK -apart from a noisy waterpump.
The wiring is a disaster- I've found 3 fuse box's and miles of surplus rubbish -yet NOTHING works -no lights at all, indicators horn etc. Wipers move occasionally.That'll be fun....
Interior is as expected. Dash seems OK -seats tatty but sound -switch's mostly non functional or wrong
So -thats going to keep me and the MIG busy for a while.
So -a few questions -if any of you can help?
Panels Any available- apart from the steps I keep seeing on Ebay -(2 needed)
I could repair these doors- but reckon I'll be sick of welding by then -and will still need interior panels winders etc- so any floating about out there?
I need a new ignition switch -can see a couple on the Bay -but any other switch's avaialble?
Help/advise very welcome.....
