2003 Transit mk6 T280 - mk7 2.2 TDCI engine conversion
Re: 2003 Transit mk6 T280 - mk7 2.2 TDCI engine conversion
Postby paul2012 » Tue Oct 17, 2017 11:21 pm
Although I had to change brake servo for a smaller one.... :oops:
Pair of Bosch batteries fitted
It's alive :P :mrgreen: & engine starts & runs
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Tue Oct 17, 2017 11:27 pm
Front end now refitted....
Also cleaned underside from front up to forward rear leaf spring hanger. Yes Fuel tank was removed too 8)
Rear underside section will be done after a couple of small repairs are completed - Pics to follow on that progress. :wink:
paul2012
Postby paul2012 » Tue Oct 17, 2017 11:47 pm
Time for some programming. Need to enable cruise control heated front & rear screen. Rear wiper & Level 2 instrument cluster for external temp display.
Using IDS you select "update/Special Function"
Enter in the code....
Select Vehicle..
Select "Vehicle configuration"
Select "Retrieve vehicle configuration data"
paul2012
Re: 2003 Transit mk6 T280 - mk7 2.2 TDCI engine comvercion
Postby paul2012 » Tue Oct 17, 2017 11:53 pm
From there you change vehicle parameters. For example Alarm
Cruise control
Dual Battery
Instrument cluster Level (Level 2 is for clusters that has messaging system & display external ambient temperature) :mrgreen:
As I have retrofitted a tailgate. I can also change that parameter too :P
paul2012
Postby paul2012 » Tue Oct 17, 2017 11:59 pm
After all relevant changes have been made.
Select "modify and reinstate vehicle configuration data"
No need to obtain "modded" file to upload to BCMII just to enable cruise control etc :mrgreen: :P 8) :wink:
paul2012
Postby fletchyfletch » Fri Oct 20, 2017 6:53 pm
Not a small task for you putting the "Transit Bible" back together. Very nice work Paul!
Your original thread taught me that I could just experiment and modify my van and that it would probably be alright in the end.
For all the failures I blame myself and you equally :lol:
Just one thing though...
I've read through all the posts that were made on this forum when Martin and others were trying to crack the illusive cruise control mod. I thought there would have to be some modified code injection at the very least.
Is it really just a case of selecting "on" in IDS?
Ford Transit Mk7 FWD SWB 2011 2.2 litre
fletchyfletch
Postby paul2012 » Tue Oct 24, 2017 4:13 pm
fletchyfletch wrote:Not a small task for you putting the "Transit Bible" back together. Very nice work Paul!
Thanks 8)
Although I trimmed this thread down & not all information that's was posted in "old" thread have been included.
As to enable cruise control etc. Yes it's simply selecting it reuploading configuration. - Once you have accessed update/special function.
I would be able to offer a postal service for members who wish to have cruise control etc enabled :wink:
If I'm correct. I should be able to enable cruise control on a standard BCMII "B". Which will save members having to obtain a BCMII "C" :P
Although I don't have a BCMII "B" to experiment with. Anyone willing to donate one to science :?: :lol: 8) :mrgreen:
paul2012
Postby Finn_Timo » Fri Nov 03, 2017 12:44 pm
Hi Paul
Nice job doing this thread again! Can you put pics and text visible from doing air conditioning afterwards? I would need that info as I am doing it to my MK6... You can PM aswell.
Ford Tourneo SWB '07 with 130HP, 9 seater bus made by PROFILE
Tonic
Also there are 1- 3 other MK6's, stock changes...
Finn_Timo
Postby paul2012 » Sun Nov 05, 2017 1:17 pm
Finn_Timo wrote:Hi Paul
I will post up required info soon. I'm still in hospital at the moment :cry:
paul2012
Postby tjm07 » Sun Nov 05, 2017 2:27 pm
Get well soon paul2012.
2008 Mk7 Swb transit crew bus 85ps
2002 BMW 320d e46 204k and counting SCRAPPED
2005 Vauxhall astra sri SOLD
2005 BMW 320i m sport
2006 Vauxhall Astra 1.4 affectionately nicknamed s#*tbox
tjm07
Postby martynx » Thu Nov 09, 2017 9:38 pm
Thanks 8)
You can enable it in a B , although in a B unit there is some circuitry missing, so as long as its not for cruise , its will be a win :) I have a spare B I can send you Paul if you'd like to have a play ?
& on the modded file point, the special function code wasn't known about some years back, so Loot & I worked out how to mod the BCM's " As_Built " configuration file manually to get the cruise & other goodies working, thats what i would send out ( sell) to people if they had IDS & wanted cruise or an axle ratio etc activating .
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby fletchyfletch » Thu Nov 09, 2017 9:52 pm
martynx wrote:the special function code wasn't known about some years back, so Loot & I worked out how to mod the BCM's " As_Built " configuration file manually to get the cruise & other goodies working, thats what i would send out ( sell) to people if they had IDS & wanted cruise or an axle ratio etc activating .[/color][/b]
Ahh that makes a lot more sense. Much respect to you guys for working that out. Im very happy we don’t have to mess about with As built anymore.
fletchyfletch
Postby martynx » Thu Nov 09, 2017 9:57 pm
Yeah much much easier now, as i had maybe 20% of the options worked out , most of the popular stuff, but it was time consuming ballache working out new stuff :wink:
On transit Customs, the option is actually selectable without entering the special function mode, but i've just remembered this is Pauls 2.22 conversion thread , i'll not mess it up with this cruise stuff :lol:
martynx
Postby paul2012 » Wed Nov 15, 2017 3:16 pm
That would be great. PM Sent
paul2012
Postby ned » Wed Nov 15, 2017 7:05 pm
You all mended now Paul, no more hospital gruel. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
