My 24v rebuild
My 24v rebuild
Postby Guy88 » Sun Jul 22, 2007 9:56 pm
As i am between vans i have decided to give the 24v a rebuild.
Main bits are
Rings
Shells
Chain guides
Chain
Oil pump
Net chain tentioner
Clean all tappits
Grind valves
New gaskets throughout
BOB cams
Im sure there will be some more
I started at 7.30 tonight and by 8.15 i had got it this far. Got the other head off now 8) 8)
One thing iv got to find is how water is getting in. No2 inlet was brim full with water :shock: :shock: None in the plenum luckily the valves were closed.
Also the condensation has started to rust the cams but i have caught it just in time
And iv finally found the Dipstick :shock: Only been 3 months :shock:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: My 24v rebuild
Postby djswampy » Sun Jul 22, 2007 9:57 pm
Guy88 wrote:And iv finally found the Dipstick :shock: Only been 3 months :shock:
Thats the thing taking the photos isn't it :P
djswampy
Re: My 24v rebuild
Postby Guy88 » Sun Jul 22, 2007 9:58 pm
Always one stating the obvious :lol: :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby djswampy » Sun Jul 22, 2007 10:00 pm
Yeah, no offence meant. Thought I'd get in there first.
taking that engine to bits looks fun. putting it back together would be the tricky bit for me :P Good Luck, Top work.
djswampy
Postby Guy88 » Sun Jul 22, 2007 10:01 pm
and the bottom chain guides are officially Fooked :(
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Sun Jul 22, 2007 10:02 pm
djswampy wrote:Yeah, no offence meant. Thought I'd get in there first.
Taking apart and putting together are easy. its remembering where and what order it should be :oops:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby custom » Mon Jul 23, 2007 9:18 am
nice one m8 hope it all goes well for you
custom
Postby Luke » Thu Aug 02, 2007 5:58 pm
quick question guy - do the inlet manifolds (after the plenum) come away from the heads or are they part of the casting :?:
Postby Guy88 » Thu Aug 02, 2007 6:26 pm
Luke wrote:quick question guy - do the inlet manifolds (after the plenum) come away from the heads or are they part of the casting :?:
They are part of the head :wink:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Fri Aug 03, 2007 10:11 pm
got me stand sorted
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby madmark » Sat Aug 04, 2007 12:50 pm
:shock: :shock: looks like you are haveing fun! :lol: :lol:
Postby Guy88 » Sat Aug 04, 2007 5:59 pm
the bare block
Main
Big end
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Mon Aug 20, 2007 9:21 pm
Right. I cannot find a supplier of parts so it will be gen ford :shock: :shock:
Not much progress
Crank has gon for a regrind
next on the list is
fit a set of 2.8i pistons to drom compression. (apparently they fit)
Fit an eaton M90 supercharger run of AC belt
find an intercooler
New plenum
Emerald mappable ECU
will be running about 14psi boost and properly mapped should see 400hp 8) 8)
will look somthing like this
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby custom » Mon Aug 20, 2007 9:50 pm
where are you getting the super charger from as thats what i want for mine and have u any info on what else i will need for the conversion any info would be greatly appreciiated cheers craig
custom
Postby Guy88 » Mon Aug 20, 2007 10:00 pm
custom wrote:where are you getting the super charger from as thats what i want for mine and have u any info on what else i will need for the conversion any info would be greatly appreciiated cheers craig
http://fordpower.org.uk/forum/index.php?showtopic=3409
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
