son in laws Mk6 Transit High top
Re: son in laws Mk6 Transit High top
Postby deadbeatdads » Sat Dec 16, 2017 11:37 pm
ok thank you
deadbeatdads
Postby deadbeatdads » Fri May 18, 2018 6:35 pm
Have been a bit quiet as of late doing other jobs, Now on with some more work on the Transit, one other job was to drop the oil, and replace filter. This was my first attempt at changing the oil on a Transit so had a quick look on YouTube, came across a guy who shows how the oil is changed. I had to use a big socket and a bit of leverage on the oil filter, only to get most of the contents of the oil down my arm, lesson learned for next time.
Oil and filter changed new oil turned black straight away so i told son in law to run it for about 2000 miles and drop it again. I dont want to use flushing oil as that may do more harm than good
deadbeatdads
Postby deadbeatdads » Fri May 18, 2018 6:51 pm
so far got it from this
Reason(s) for failure
Rear registration plate missing (6.3.1a)
Nearside Front Headlamp aim beam image obviously incorrect bulb not fitted correctly (1.8.A.1b)
Nearside Rear Stop lamp not working (1.2.1b)
Offside Rear Statutory seat belt missing (5.1.1)
Rear Statutory seat belt missing centre (5.1.1)
Nearside passenger door cannot be opened from outside the vehicle sliding door (6.2.B.1c)
Nearside passengers seat insecure rear seat broken from weld (6.2.A.1)
Offside Front Seat belt anchorage prescribed area is excessively corroded drivers door step (5.2.6)
Offside Front Inner Seat belt anchorage prescribed area is excessively corroded step to inner sill (5.2.6)
Offside Front Seat belt anchorage prescribed area is excessively corroded inner arch (5.2.6)
Offside Front Seat belt anchorage prescribed area is excessively corroded inner sill (5.2.6)
Nearside Rear Suspension component mounting prescribed area is excessively corroded inner valance /sill (2.4.A.3)
Nearside Inner Suspension component mounting prescribed area is excessively corroded sill from front to rear (2.4.A.3)
Nearside Front Seat belt anchorage prescribed area is excessively corroded inner step (5.2.6)
Nearside Front Seat belt anchorage prescribed area is excessively corroded inner sill (5.2.6)
Nearside Front Inner Suspension component mounting prescribed area is excessively corroded arch to step (2.4.A.3)
Offside Rear Inner Suspension component mounting prescribed area is excessively corroded sill (2.4.A.3)
Offside Front Seat belt anchorage prescribed area is excessively corroded outer sill (5.2.6)
Nearside Rear Suspension component mounting prescribed area is excessively corroded outer sill (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is excessively corroded outer sill (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is excessively corroded outrigger (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is excessively corroded valance/inner sill (2.4.A.3)
Nearside Rear Suspension spring mounting prescribed area is excessively corroded leaf spring mount (2.4.A.3)
Nearside Front Suspension component mounting prescribed area is excessively corroded inner arch (2.4.A.3)
Offside Front Inner Suspension component mounting prescribed area is excessively corroded arch (2.4.A.3)
Offside Front Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
Offside Front Coil spring not correctly located (2.4.C.2)
Central Rear Drive shaft uj which forms part of the suspension has excessive play in a universal joint (2.4.G.4b)
Central Drive shaft which forms part of the suspension support bearing excessively worn middle (2.4.G.4d)
Nearside Rear Valve stem seriously damaged (4.1.D.1e)
Emissions not tested (7.3.A.1)
Exhaust emits excessive smoke or vapour of any colour (7.4.B.4)
to this
• Nearside Rear Stop lamp not working (1.2.1b)
• Nearside passenger door cannot be opened from outside the vehicle sliding door (6.2.B.1c)
• Offside Front Seat belt anchorage prescribed area is excessively corroded inner arch (5.2.6)
• Offside Front Seat belt anchorage prescribed area is excessively corroded inner sill (5.2.6)
• Nearside Inner Suspension component mounting prescribed area is excessively corroded sill from front to rear (2.4.A.3)
• Nearside Front Inner Suspension component mounting prescribed area is excessively corroded arch to step (2.4.A.3)
• Offside Front Seat belt anchorage prescribed area is excessively corroded outer sill (5.2.6)
• Offside Rear Suspension component mounting prescribed area is excessively corroded valance/inner sill (2.4.A.3)
• Nearside Front Suspension component mounting prescribed area is excessively corroded inner arch (2.4.A.3)
• Offside Front Inner Suspension component mounting prescribed area is excessively corroded arch (2.4.A.3)
• Offside Front Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
• Offside Front Coil spring not correctly located (2.4.C.2)
• Central Rear Drive shaft uj which forms part of the suspension has excessive play in a universal joint (2.4.G.4b)
• Central Drive shaft which forms part of the suspension support bearing excessively worn middle (2.4.G.4d)
• Emissions not tested (7.3.A.1)
• Exhaust emits excessive smoke or vapour of any colour (7.4.B.4)
deadbeatdads
Postby deadbeatdads » Fri May 18, 2018 7:10 pm
and now started on the near side rear
deadbeatdads
Postby deadbeatdads » Fri May 18, 2018 7:15 pm
some more welded up
deadbeatdads
Postby deadbeatdads » Fri May 18, 2018 7:22 pm
some more
deadbeatdads
Postby deadbeatdads » Fri May 18, 2018 7:28 pm
Making sure i keep the hole ready for wax oyling later
deadbeatdads
Postby deadbeatdads » Fri May 18, 2018 7:32 pm
Part dressed welds with some primer sprayed over for time being to stop any new rust
deadbeatdads
Postby deadbeatdads » Fri May 18, 2018 7:35 pm
a little bit of corrosion near spring hanger cut out and a new fresh piece of 2 mm place welded in
deadbeatdads
Postby deadbeatdads » Wed Jun 20, 2018 8:38 pm
Near side sill, this was what we were faced with once we pulled off the long strip of metal that was stuck in place with sealer, not even welded in
deadbeatdads
Postby deadbeatdads » Wed Jun 20, 2018 8:41 pm
and more
deadbeatdads
Postby deadbeatdads » Wed Jun 20, 2018 8:42 pm
a closer look
deadbeatdads
Postby deadbeatdads » Wed Jun 20, 2018 8:46 pm
We set out cutting out the rot and getting back to clean metal, which there was very little underneath this side
deadbeatdads
Postby deadbeatdads » Wed Jun 20, 2018 8:52 pm
getting to the clean stuff revealed other holes as you could see
deadbeatdads
Postby deadbeatdads » Thu Jun 21, 2018 8:52 pm
New metal went in and a new paret inner sill was shaped out of 2mm plate and was welded in. A few people told me to use angle line but i thought the 2mm plate shaped would look tidier.
Some of the outer sill had to be ref abricated
deadbeatdads
