Mk5 Rust Fixing [Pics]
Postby hdegroot » Tue Oct 09, 2007 8:18 pm
Because someone destroyed my post i do it all over again:
My mk5 looks good in the pics but if you look closer you can see rust coming true i also noticed it is going faster every year, so i started with rust convertor and a screwdriver and some sanding paper:
Moisture gets stuck between the rubber and the steel causing the rot.
And one wheelarch the other side is without rust. note: one of my rear wheel arches is rotting too :oops:
chipped away all the pain that was bubbling and applied the rust converter. Friday i will start painting it...have to go to school first :roll:
also i got 2 new wheelcovers!
MK5 150 LWB TD
Volvo C 3 0 3 4x4
hdegroot
Re: Mk5 Rust Fixing [Pics]
Postby hdegroot » Sat Oct 13, 2007 8:52 pm
Rear door, before
after...note: the white stuff is some degreaser
The other door after sand papering it.
Fords finest radiant red...from 1990 (yes we had a mk4 150 lwb 80ps before this)
Some damage repaired after my mom drove the van :roll:
Drivers side front wheel arch fixed
i'll apply the next layer tommorow
comments???
MK5 150 LWB TD
Volvo C 3 0 3 4x4
hdegroot
Postby hdegroot » Tue Oct 16, 2007 3:41 pm
did the seconds layer yesterday...today its raining maybe pics tommorow...any comments??
MK5 150 LWB TD
Volvo C 3 0 3 4x4
hdegroot
Postby Luke » Tue Oct 16, 2007 5:28 pm
good job mate :D i use a sanding disk on the angle grinder to get all the surface rust off then use the kurust/rust converter - not sure how good the stuff is, its difficult to say but i always figure its better than none :D
you have caught it in time and its best to do what your doing to keep on top of it 8)
Postby hdegroot » Thu Oct 18, 2007 5:18 pm
Started working on the sliding door strip by spraying ML Tectyl from above
So that it ended behind the sliding door strip...then started again with a screwdriver and cut the rust away and applied the convertor
Some idiots dont know how to open doors
MK5 150 LWB TD
Volvo C 3 0 3 4x4
hdegroot
Postby AndyG » Thu Oct 18, 2007 11:51 pm
Glad to see you're looking after it :!:
That rail looks as though it'll have to come out for a successful repair :!:
Isn't it held on with small nuts from the inside :?:
Shame about the door :( :evil: :roll: Tell 'em they can't use it anymore :P :lol:
Postby hdegroot » Fri Oct 19, 2007 9:57 am
Andyg wrote:Glad to see you're looking after it :!:
Yes it feels good that i am keeping it in good shape, i am not sure about the rail but i will remove the ply on the inside to have a look soon.
Yes some people are idiots and slamming the door like it is a sprinter :lol:
MK5 150 LWB TD
Volvo C 3 0 3 4x4
hdegroot
