Victoria Aust. 1980 van
Re: Victoria Aust. 1980 van
Postby oldskooler » Sat Jun 27, 2009 4:05 am
cracking looking van you got there, 8)
oldskooler
Postby deankdx » Sat Jun 27, 2009 9:56 am
oldskooler wrote:cracking looking van you got there, 8)
thanks mate, hope to do a heap of miles in it too
1980 Mk2 4.1 litre 5 speed manual, 2.77 or 2.92 falcon diff conversion, falcon front discs.
project thread herer viewtopic.php?f=27&t=24731&start=60
deankdx
Postby irishtransit » Sat Jun 27, 2009 11:59 pm
that's a beaut you have there.
irishtransit
Postby robert dale » Mon Jun 29, 2009 7:43 am
gday dean. did you change the front brake set up to falcon discs yourself or was it already done when you got the van, i am starting to do mine and information on the way to do it would be appreciated and will save a lot of dummy spitting thanks bob
robert dale
Postby deankdx » Tue Jun 30, 2009 1:38 am
robert dale wrote:gday dean. did you change the front brake set up to falcon discs yourself or was it already done when you got the van, i am starting to do mine and information on the way to do it would be appreciated and will save a lot of dummy spitting thanks bob
this was already done when i got the van, same for the diff.
i think from Memory of when Dad did his Mk1 it needed a custom braket to mount the caliper. it runs Falcon discs with PBR HQ kingswood caliper. and i assume by the looks the brake hoses are also kingswood.
CRS might have a kit? http://rodshop.com.au/
hoppers stoppers also http://www.hoppers.com.au/
i cant find the bloke this kit came from, but hes a transit wrecker in Cheltenham Vic.Au BJ automotive i think its called.
irishtransit wrote:that's a beaut you have there.
Thanks Mate, dont see them about much anymore.
deankdx
Postby deankdx » Wed Jul 08, 2009 1:05 pm
well, a little more progress.
spend a few hours chipping away with the hoses and gas mixer and converter locations.
normally the coil is mounted under the carby on the engine block, but thats almost directly under the water drain in the heater air intake.
besides if there was ever a need to work on it, its accessable easy now.
not sure why the water pump heater return is 3/4 size. but i am going to get a 3/4 fitting screw it to the other T piece i have and run a short length of 3/4 hose to it. normally theres a 5/8 hose with a 3/4 flare on it. (not something i want to rely on someone having in stock if i need one in the middle of nowhere.)
will be rewiring the headlights with a Big relay and will swap to globe type instead of the sealed beams also. as the headlights were useless when i drove the van home at night.
hope to spend a bit of time on it tomorrow and hear it running at least on petrol (weather forcast turns bad after tomorrow, back to winter weather)
deankdx
Postby Luke » Wed Jul 08, 2009 5:55 pm
all coming together now 8)
Postby deankdx » Thu Jul 09, 2009 8:27 am
Luke wrote:all coming together now 8)
spent some more time today finished the hoses off(couldnt get the brass fitting i wanted so bought the flared hose instread)
noticed the accelerator is dodgy at the pedal end, so will have a look at wether a falcon one can be easily adapted
anyway will sort the electrics next, if weather allows
heres a quick vid of the sound.
http://www.youtube.com/watch?v=Mpxw1DkFMlI
deankdx
Postby madmark » Thu Jul 09, 2009 3:27 pm
8) very nice mate! :wink:
Postby deankdx » Fri Jul 10, 2009 9:17 am
well, did a little more tinkering today.
decided i would move the indicator switch to the correct side,had to drill 2 new locating holes in the steering column to mount them correctly.
i need to extend the wiring next to make them work.
i hate the headlight switch on the stalk as i have bumped the wipers on accidently which doesnt wipe very well on a dry windscreen.(i will cut it off flush.)
so i am going to fit a cortina TE headlight switch, has dimming control for the dash lights and also can switch an iterior light on with another output. i have a full cortina loom here to chop up but i'll leave most of the Transit wiring for the lights as is.
i am thinking of using the TE headlight wiring plugs and a section of loom though with a big dual circuit relay.
nothing looks any different yet, but i have the dash in lots of pieces. i'll also wire up the cortina tacho cluster which i think i have the wiring sorted for that now also.
deankdx
Postby deankdx » Tue Jul 14, 2009 8:51 am
well. it doesnt look much different
But, now it starts and runs on gas. petrol/gas wiring is complete. converter and lockoff mounted and so is the charcoal cansiter.
under bonnet is nearly complete, will just find the wires for the oil pressure and temperature senders (or run new wires)
wire my headlight relay, and fit up fan belt and radiator etc.
going to be concentrating on dash wiring etc next, got to work out why the heater fan isnt working too
deankdx
Postby deankdx » Sat Jul 18, 2009 1:55 pm
well, got a vid of the exhaust sound while on gas. http://www.youtube.com/watch?v=eATuqWmqCOw
wired the original headlight switch, wipers and indicator stalks for the opposite side mounting
seems to be fine,
started wiring up My cortina cluster and am having a few issues.
looks like i need to figure out where the voltae regulator is for the oil,temp,petrol guages cos they dont work. not sure if its dead or missing a wire yet.
and i cant figure out how to wire up the brake fail light, its got a falcon master cyl with 2 wires off it.
will get there in the end i spose.
deankdx
Postby Luke » Sat Jul 18, 2009 2:10 pm
8) 8)
some of the regulators will swap over (just screwed on) on those style clusters - they are a bit puzzling when swapping dashes as all the wire connections are in different places :lol: but you'll get there 8)
Postby deankdx » Tue Aug 11, 2009 2:17 pm
well, still chipping away
found the heater fan resistor all mangled, going to look at cutting the hole bigger in the heater box and fitting a falcon fan resistor.
havent tested the fan yet, but cant see it not working?
gave up on the cluster wiring for now, and half way through the headlight wiring with relay and H4 globe type headlights.
took my front brake hoses to be remade which came up great for $50 the pair, now a litttle shorter as they were rubbing on steering parts.
the rear axel seal leak should be fixed by swapping the whole axel from another falcon diff i have here. and i fitted the near new rear brake shoes and wheel cyls from another diff i had here. have to pick up my drums from being machined tomorrow, then bleed the brakes.
got some rubber bushes to source, and some rust to repair, but not a lot left on the list now.
nothing worth taking a photo of in this post though. exept the state of the dash at the moment
deankdx
Postby greek » Thu Aug 13, 2009 9:24 pm
Wonder if any of you guys in aus know of a mk1 longwheelbase twin wheeler Bright Yellow lovely nick. last I saw of it was on a campsite up in Narrabean North Of Sydney.The bloke that owned it sold Ice cream & Pie`s all from the same van got it on video but never got a pic of it, Anybody help :?:
I`m to old to lie under Transits
greek
