Victoria Aust. 1980 van
Re: Victoria Aust. 1980 van
Postby deankdx » Fri Aug 14, 2009 12:24 am
greek wrote:Wonder if any of you guys in aus know of a mk1 longwheelbase twin wheeler Bright Yellow lovely nick. last I saw of it was on a campsite up in Narrabean North Of Sydney.The bloke that owned it sold Ice cream & Pie`s all from the same van got it on video but never got a pic of it, Anybody help :?:
i'm a long way from sydney, probably 1000kms havent been there myself yet either.
there a lot of Transits converted to icecream or hot food vans though, but the older ones are getting rare.
1980 Mk2 4.1 litre 5 speed manual, 2.77 or 2.92 falcon diff conversion, falcon front discs.
project thread herer viewtopic.php?f=27&t=24731&start=60
deankdx
Postby deankdx » Sat Aug 15, 2009 6:45 am
well, bit more work today
finished off the brakes, see the pic of the diff oil soaked linings,
good secondhand set were fitted, and new brake lines on the front.
the heater fan works when hooked to striaght 12v.. got to sort out the wiring there still.
the heater box was absolutly full of leaves, vacuumed what would be close to a bucket full from there, and a redback spider and nest too, not something you want blowing onto your face from the vents.
i'll put some flywire/shadecloth accross the vent under the bonnet i think, not really intersted in cleaning it out from leaves or spiders again.
also fitted a number plate light, the originals are there, but not working and cant work with the current bumper fitted anyway,
tightened the couple of loose bolts that were picked for RWC.
all i really need to do now is finish the headlight wiring and horn relays then get the dash working and back together, polish the windscreen marks, and fix some rust spots.
could happen pretty quick from here.
deankdx
Postby Luke » Sat Aug 15, 2009 11:21 am
deankdx wrote: not really intersted in cleaning it out from leaves or spiders again.
especially when the spiders could kill you :lol: :lol:
good work mate 8) 8)
Postby irishtransit » Sat Aug 15, 2009 11:51 pm
nasty little blighters them spiders.good looking work there.
irishtransit
Postby kiwi_mk2 » Sun Aug 16, 2009 8:58 am
Hi there, i have just fitted that brake conversion to my van, what part # or what vehicle are the brake hoses off?
Cheers
I want to take my van to Gatwick and park it in the Transit lounge!
kiwi_mk2
Postby deankdx » Sun Aug 16, 2009 1:25 pm
kiwi_mk2 wrote:Hi there, i have just fitted that brake conversion to my van, what part # or what vehicle are the brake hoses off?
Cheers
it had HQ holden Kingswood brake lines fitted when i got it(suiting the HQ caliper), they fit easy, but are about 100mm too long
i just got new hoses made up to suit the application, only cost $50 the pair anyway and i doubt i'll need to replace them in the next 20 years
deankdx
Postby deankdx » Sat Aug 22, 2009 3:28 am
nice day here for working on the van again today.
just got the Falcon heater fan resister working outside the heater box, need to make the hole bigger to fit it, but thats another off the list
on investigation i need to now fix up the vent control cables, none work like they should.
should get the headlight wiring done today,
want to have the horn and washer working also, then i can refit the front panels and be done there.
if all goes well. i should only have rust to do in a weeks time. then its ready for the road.
deankdx
Postby deankdx » Sat Aug 22, 2009 11:25 am
well, i have to redo my headlight relay, the relay itself is damaged.
will fit 2 Falcon ones(this transit is becoming Falcon more Falcon every day)
the fan resister works fine, probably more reliable.
the rust under the left windscreen is worse than i expected, but still fixable easy enough,(especially after seeing some others on here fixed)
should spend a few more days next week ficing a few things
deankdx
Postby Luke » Sat Aug 22, 2009 12:24 pm
yeah thats not too bad :D i see it been done before with the wig wire sticking through :lol:
cut it all out and it'll be good as new 8)
Postby irishtransit » Sun Aug 23, 2009 12:22 am
wouldn't be a transit if there wasn't any rust :)
irishtransit
Postby deankdx » Sun Aug 23, 2009 12:36 am
irishtransit wrote:wouldn't be a transit if there wasn't any rust :)
is there a SHOW US YOUR RUST thread on here? if not, there should be
deankdx
Postby deankdx » Fri Oct 08, 2010 3:31 am
Hi, long time no progress here. heaps of distractions, and bad weather.
just about to start spending more time on it again.
think i have bitten off more than i can chew with this idea with the dash, but i will be looking at some point after the rego/rwc is done.
needs a bit of trimming of the metal dash, and the falcon dash pad, but its not far off(will need some cutting and welding of the metal for sure)
still thinking about the falcon steering column mated to the transit steering shaft too. would make life much easier, and its collapsable.(not that i want to test that out.)
deankdx
Postby Franfixit » Mon Jul 25, 2011 11:13 pm
[quote="deankdx"]Hi, long time no progress here. heaps of distractions, and bad weather.
Hey there...How's it going?...or are you still at a stall point?.....Oh...and I can't resist this......'there was a redback in my heater box, when I went there last night.
I couldn't see it in the dark, but boy I felt it's bite!!'
If you didn't build it yourself...It isn't really yours (Tim the Toolman Taylor)
Franfixit
Postby deankdx » Tue Jul 26, 2011 2:00 am
Franfixit wrote:
deankdx wrote:Hi, long time no progress here. heaps of distractions, and bad weather.
Damn, sure it was a redback? thought they need hospital?
those black spiders that make nests in the windows of houses are everywhere in mine at the moment.
i just built a garage, winter was too cold to be doing outside work where possible.
i decided to fix my ute(XF falcon) as it would be far quicker, then the transit is next in there. maybe in a month, should see some progress one way or another.
deankdx
Postby Franfixit » Tue Jul 26, 2011 10:19 am
deankdx wrote:Damn, sure it was a redback? thought they need hospital?
No Arachnid altercations for me....I just got inspired by the spiders in your Transit venting system to rework the classic 'redback on the toilet' seat song to suit your story...Victoria..Australia....I'm one of 'those' citizens who ran away to Queensland..so I understand the weather predicament.
I'll keep an eye out for when you're able to get back into it.
Franfixit
