mk4 LWB Project! UP DATE! one side nerly done in blue !!!
Postby intransit89 » Wed May 21, 2008 11:48 pm
:D 8) this is just a example to see if i realy like orange :) :wink:
it was rubed down with sand paper then some plastic white primer then high build primer then a rub down then a other coat of white normal primer then orange.
was 5.00 from a local scrapy!
my van for 200.00 in dec 06 2007 :D
after a week of owning it i started work on her!
here some pictures
the flags pictures gone :wink:
now the front floor
before
after
cleaned
now in side the back tock floor up and seems good to :D
i think got this two weeks latter for 40.00 to make some seat adapters for customizing some seats i got a eye on in the scrapy :!:
did some more work to her
then got some body care :lol: for the transit as you never find rot :lol:
the lot come to 40.00 in clueing vat
theres
boddy filler 600ml
glass fibre 250ml
white primer 600ml
satin black 600ml
stone gard white 1L
diesel injector clearner
some lock bolt undo cleaner
and 250ml of hammwerite for the van floor in side :wink
then got some wheel trims for 12.00 to tidy her up a little
painted the wheels black 1st
got my seats i got my eye one
for the sum of 10.00 the pair :D
i then got to work to put them in using the thick steel and got them in 8)
heres pics to show you
this was before
after
some
pics of the inds and back lights to back on the van :wink:
did some customizing to the front end :wink:
both done
now back light
before
after
still doing them now
and then after dinna giving them a coat of clear lacquer
intransit89
Re: !!Intransit89 LWB MK4 Project!!please dont post on here yet!
Postby captain hook » Thu May 22, 2008 12:06 am
WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN
captain hook
Postby intransit89 » Thu May 22, 2008 12:09 am
captain hook wrote:WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN WEIGH IT IN
some people are stupid :lol: :roll: :roll: :roll:
intransit89
Postby intransit89 » Thu May 22, 2008 12:10 am
had a look round her to day and it needed some panels so i did a order from beevers
8)
so it not be rust box after :wink:
seeing as beevers sent me the wrong part for the spring hanger so i made my own 8) :lol:
home made spring hangers using 2mm steel
this is the photoshoped pics of what i plan to do my van as a finshed project :!:
starting the body work
img]http://i109.photobucket.com/albums/n57/intransit89/vw%20dub%20van/IMG_1490.jpg[/img]
intransit89
Re: !!Intransit89 LWB MK4 Project!update carpeting door cards
Postby intransit89 » Thu May 22, 2008 12:19 am
started to clean the in side out!
ready to carry out work
ttp://i109.photobucket.com/albums/n57/i ... G_1513.jpg[/img]
than a bit of primer
intransit89
Postby intransit89 » Thu May 22, 2008 12:25 am
than started some welding
so i started this,
as you can see i tock the door of so i can work on it better but now all back together and sorted 8)
still got to weld a patch on the sill and on top on the floor nere the front iner arch :wink:
i just finshed it of heres some pics it does close ok,
i stil got to weld these bits yet on this side.
right the drivers side to do :lol:
good job i have the front arch and sill new panels.
sill
arch and step repair i got to do
a other day now to tidy the welds with grinding etc then body filler over to make it all smoth.
i did spray some underseal in where i cut the rust out and sprayed some waxoil to :wink:
still finshing the left side body filler to smooth it of
the body filler got to be sanded down yet it :wink:
but its better then it was :)
i then made a start on the pass side door to :!:
as it was roten a bit
got other side front door to do to but this pass side door and arch and sill done and i put loads of bitcho on the unside new front arch and wing so no mud gets there and gobs it up again :wink:
its good what you can do with in 2 hours
intransit89
Postby intransit89 » Thu May 22, 2008 12:30 am
started the other side sill and front arch drivers side :D
i still got to drill some holes along the sill to weld plug it then grind down the welds then body filler and then i will start taking the drivers wing of to weld up the inner wing :wink: :D
please note the inner sill was roten so i welded a new pice from the back and then where you see the hole that was choped out i plated that to before the sill went on but i put some spray on under seal on it :wink:
as there was a bit of wind so i had to leave it for a day or two and come back to it
heres it geting there
i then grinded down the welds and body filler over them :wink:
intransit89
Postby intransit89 » Thu May 22, 2008 12:32 am
as my back doors was roten with being 14 years old so got a better pair of a v REG
on with the new thay even close mint to :D
intransit89
Postby intransit89 » Thu May 22, 2008 12:36 am
i then after finshing the drivers side sill and arch started the inner wing ! was bad then it looked once you get picking!
well tock the wing of to get the inner wing welded up
the drivers side wing looks like it had a new one on but it looked a bodge job more seam sealer then welding :lol:
so there had to be some home made inner wing to start so here i started :lol:
this is a pic so you can see for your selfs what iam doing!
and heres the inner wing iam making!
simple realy get some steel out of here :lol:
them make some carboard templates and then put them on to steel plate and draw round and cut out! looks like this!
thats all i done so far :!: will carry on with it
a other day whe i have one spare :lol:
intransit89
Postby intransit89 » Thu May 22, 2008 12:37 am
well did this to day!!
geting there!!!
:wink:
lession learned to day !!! take out much stuff out way you can before welding!!
or you set fire to you van like i did
luckly it only mated 3 wired in thw wire loom and one from the fues box
as i had no revesing lights/ or brake lights or radio or in side cab light
but i replaced the burned together wires and hay presto it works again!!!
only burnt my bonnet cable but it still works will get a other one from scrapy and maybe a servo cap as i never had one!!
heres the dash out as i was doing the wires!!
gona go back out now and finsh it of!!!
as got to move the van tomorow!
intransit89
Postby intransit89 » Thu May 22, 2008 12:39 am
i stone chiped the front end as well
and done a bit on the side of van in primer!
where you see its not been done its because iam gona take it all of and the arch as i got new panels to go on!!
now on this pic i tock the air box of so i could bitcho the out rigger!
see pic also cleaned the power steering pipes and tock the sponge out!!!
intransit89
Postby intransit89 » Thu May 22, 2008 12:41 am
heres some more pics of the primer on drivers side and some body work on the pass side :!:
and some trial of the new paint i got 8)
intransit89
Postby intransit89 » Thu May 22, 2008 12:47 am
started more welding on the step well :!:
then got a bulk head for 10.00 :wink:
then i was starting to weld the back end up. :x
but ran out of gas :!:
was going good as you see now got to wait 4-8 days for a refil
:cry: :x
intransit89
Postby intransit89 » Thu May 22, 2008 12:51 am
was then busy since still waiting for my gas bottle to come :x
its black stone chip on floor ans white in the door steps !
then over the white stone chip with orange 8)
got my new mat in to :D
there you go
i then also started doing behind the bulk head to make in to a sleeping part :!:
just got to fitt the lino tomororow as i got the day of :D
i might make a fold down bed to latter on in the year :!: :wink:
heres some pics behind my sleeping cab :lol:
usal pics in side at the back of a transit van :lol: :oops: :D
:wink:
intransit89
Postby slow transit » Thu May 22, 2008 9:41 am
All now in 13 posts :? :shock: :lol:
Instead of 640 posts :lol: :roll:
slow transit
