transit.jono wrote:Thanks-done deal-----Cheers.
.... did you send them ? because i dont think i have seen anything in my email today, unless mailwasher bounced it back to you.
interesting "work in progress" picture, i am still trying to get my head around what your doing there .......
working from right to left, the first hole i guess is to the outer side of the chassis rail ... is that ground i can see through it ? (hard to tell as it seems out the same colour) or is the chassis "doubled up" at that point, just looks too wide and with an upright piece in the center of it
Then the next sort of hole looks into the chassis rail, right ?
Then you seem to have what looks like 5 repair strips/sections, like you had done one strip for each section either side of the rib then welded a ribbed section in, alll except that middle rib, or did you weld one flat piece in then add the raised rib section after to keep the profile correct ?
(i am sort of lucky as i have access to bending facilities so if i need to i can do stuff all in one like that, but generally tend to just use thicker stuff
then on the far left another hole ..... did that one sneak up on you ?
... i know that feeling when you make a plate up and then find the metal to one side was not so good and you end up with a patch on the end as well !! ..... thats why i now make templates up first and mark those onto the vehicle and clean around it before i even cut the metal for the new panel
