transit.jono wrote:now where's that angle grinder????
Jono
one chassis cab coming right up !!!!!!
forgot to say .... trick for you, get the drill out first and drill through all of the spot welds, use a drill bit a little bigger than the welds, then when you come to weld it up you can use those holes to weld the chassis to the new floor, no need to drill holes in the new floor that way
.... only downside is you'll be welding on your back for a while to get them all done rather than doing it from the top .... advantage is less cleaning and dressing of the welds though
and i doubt you will burn off quite as much of the paint from the new floor doing it this way, but if you mark the holes first and then clean around the marks then spray with weld through primer that should help preserve it
