Argro wrote:I was hoping to see someone whos done a Dash converstion, I wanna see how to get around the gear stick being on the dash, But i am thinking of having the front changed on mine but im taking it to a body shop, Also I heard you have to change the fuse box, Modify the radiator brackets and wire the indicators up, Sounds complicated, so I hope you give loads of info mate, And look foward to seeing it complete, And where did you get those sport wheels from?, I would like a set of those but I think there expensive. And How much did you pay for the front? Also will changing the front effect insurance? Sorry about all the questions :S
No radiator mods necessary , if use full front your replacing , slam panel
Bumper bar and mounts , found it easy myself , scuttle is difficult snd the legs and wings
But only a few days work if good with welder
Indicators - either swap plugs or just get into the light and tap into indicator loom !!
Love an engine upgrade but not sure I could afford the st mod, any ideas for best engine upgrade with changing as little as possible ! Cheers in advance guys
