cossie bits
cossie bits
Postby niceonesquire » Sat May 18, 2013 7:13 pm
i know some of you on here have used the cossy boa and 2.9 v6 etc does anyone have a manual flywheel and clutch bits etc im converting mine from auto to manual so need a few bits to do the conversion if anyone has bits let me know.
niceonesquire
Re: cossie bits
Postby mb4ever » Sat May 18, 2013 7:19 pm
niceonesquire wrote:i know some of you on here have used the cossy boa and 2.9 v6 etc does anyone have a manual flywheel and clutch bits etc im converting mine from auto to manual so need a few bits to do the conversion if anyone has bits let me know.
eBay listings
mb4ever
Re: cossie bits
Postby niceonesquire » Sat May 18, 2013 11:44 pm
does that not seem expensive to you or do these things fetch a premium i have no clue.
niceonesquire
Re: cossie bits
Postby mb4ever » Sun May 19, 2013 8:43 am
niceonesquire wrote:does that not seem expensive to you or do these things fetch a premium i have no clue.
It seems expensive to me, on the other hand, eBay tends to set the prices.
I suggest you watch them,
And contact this guy, it may still be for sale.
eBay listings
mb4ever
Re: cossie bits
Postby RP123 » Sun May 19, 2013 9:30 am
What gearbox are you planning on using, type 9 5 speed or the transit mt75 box? (For the mt75 transit box it uses different flywheel and adapter plate between engine and box)
I have a v6 type 9 car type gearbox and also the correct transit type 9 gear linkage that could be fitted to the v6 car type gearbox, the gearbox also has a v6 alloy bellhousing. I have a 2.9 efi engine with flywheel and clutch on it.
Its worth mentioning as I have found out myself recently that the proper transit v6 stuff is quite different and quite rare and some say the type 9 gearbox is not man enough for the transit but I don't have experience of type 9's in transits so can't vouch for that.
I bought the above bits as I'm fitting 2.9 v6 etc into my mk1 but after discussions on this forum I have since bought a complete proper s.v.o v6 transit to use as my doner vehicle. :wink:
1999 Tourneo GLX85PS
1973 Mk1 Transit Canterbury savannah
1963 Mk3 Zodiac
1964 Anglia 105e
RP123
Re: cossie bits
Postby niceonesquire » Sun May 19, 2013 10:20 pm
not going to use the trad bolt on stuff im going to use the mt75 box and make the rest myself but need the flywheel to start with.
niceonesquire
Re: cossie bits
Postby mb4ever » Mon May 20, 2013 10:01 am
niceonesquire wrote:not going to use the trad bolt on stuff im going to use the mt75 box and make the rest myself but need the flywheel to start with.
Sounds interesting.
Please will you keep us up to date as your project progresses?
Especially with pictures, as they say, a picture is worth 1000 words. :)
mb4ever
Re: cossie bits
Postby niceonesquire » Mon May 20, 2013 8:43 pm
i will try it could be interesting or it could all go pete tong we shall see
niceonesquire
Re: cossie bits
Postby mb4ever » Mon May 20, 2013 9:04 pm
niceonesquire wrote:i will try it could be interesting or it could all go pete tong we shall see
It'll go Fred Wright, especially if you keep us all up to speed.
That way we'll all be cheering you on, and chipping in with some ideas if you ask for them.
Look forward to the first post.
When you starting please?
mb4ever
Re: cossie bits
Postby niceonesquire » Tue May 21, 2013 9:31 pm
hopefully be starting soon once i get a flywheel.
niceonesquire
Re: cossie bits
Postby Boffin » Wed Jun 05, 2013 6:01 pm
i used a 2.8 granada flywheel, used a transit diesel mt75 gearbox out of a 1998 S reg transit, transit clutch plate and pressure plate made an adaptor plate,im not very good on the computer or i'd get some pictures, mine's in a mk2 transit van swb,i took it up Santa Pod strip at the weekend and with a standard cosworth boa did a 15.9 second run.could probably go quicker without the bed and crap in the back. where abouts do you live? im down south in Bournemouth, so maybe able to help.
Boffin
Re: cossie bits
Postby niceonesquire » Wed Jun 05, 2013 9:46 pm
thats basically my plan but with a petrol box instead cause thats what i have!
niceonesquire
Return to Mk 1 & 2
