Brake Master Cylinder Help/info Please
Postby steve andrews » Fri Jul 18, 2014 11:59 am
Well long story short brakes not bleeding on our diesel mk1 which is a Di. The master cylinder is at fault the bore size is 24mm and we are looking for a seal kit, any help or the seal kit for sale would be great or a complete master cylinder. Thanks in advance chaps
Only Milk And Juice Come In 2 Litres....
steve andrews
Re: Brake Master Cylinder Help/info Please
Postby Mr RVM » Fri Jul 18, 2014 4:45 pm
steve andrews wrote:Well long story short brakes not bleeding on our diesel mk1 which is a Di. The master cylinder is at fault the bore size is 24mm and we are looking for a seal kit, any help or the seal kit for sale would be great or a complete master cylinder. Thanks in advance chaps
Do you have a picture of it, to show the pipe connection set up it has :?: also does it (your van) have a servo ? Its sometimes not worth the bother of fitting a seal kit (they can often cost as much as you could get a good used or "new old stock" complete master cylinder for) I have a couple for sale in the "parts for sale" section (with pics) but not sure of which transit they are for (definitely not Mk5) :?:
Mr RVM
Postby steve andrews » Mon Jul 21, 2014 3:18 pm
Yeah has servo, would appear the actual size is 23.8mm it has twin reservoirs. The master cylinder is at my old mans just now so no pic
steve andrews
Postby davek » Tue Jul 22, 2014 8:47 pm
I got a seal kit from here:- http://www.biggred.co.uk
davek
Postby jonochap » Tue Jul 22, 2014 10:17 pm
Piccys would be helpful ;)
jonochap
Postby shaggy n daphne » Fri Jul 25, 2014 12:53 pm
Seal kit didn't work for me, hope it does for you. If not there is a helpful guy at Doctor car parts they are on ebay but I would ring and check you get the right part
I ordered the wrong part but it looked the same on ebay, Then decided to make it fit (it didn't work idiot :( ). Had to buy another one. Anyway It cost £65 and here's the phone no. 0115 7270110 Good luck
shaggy n daphne
Postby steve andrews » Tue Jul 29, 2014 9:17 am
Halleluah.... thanks for the replies i spoke to biggred very very helpful offered to send out both kits and just send back the one i didnt need, however after taking the master cylinder to my local motor factors they sorted out a brand new one so Poppy has now got brand new hoses and master cylinder, flushed out the old shitty fluid too HAPPY HAPPY DAYS. Ready for our summer hols now :D
steve andrews
Postby jonochap » Tue Jul 29, 2014 7:59 pm
Well done :)
jonochap
Postby steve andrews » Thu Jul 31, 2014 10:07 am
Cheers, just for reference ours has the early di and the chap must've put the servo and master cylinder from the mk2 in, so the part number for the brand new master cylinder is... MCY 368
steve andrews
Postby Mr RVM » Thu Jul 31, 2014 11:14 am
steve andrews wrote:Cheers, just for reference ours has the early di and the chap must've put the servo and master cylinder from the mk2 in, so the part number for the brand new master cylinder is... MCY 368
And it looks like this :?: :?: :?:
Mr RVM
Postby steve andrews » Fri Aug 01, 2014 8:43 am
Yeah mate, time wasnt on my side regards pics post/send then waiting on Royal Snail to deliver at their leisure or i would have purchased from you, hope this helps some of the others tho :D 8)
steve andrews
Postby Ellwood » Sun Oct 12, 2014 10:07 am
assuming your brake hoses are 40 years old, they are probaby clogged inside, like mine were. a good idea to change them while you are on .
Ellwood
Postby Mikemax1984 » Mon Apr 23, 2018 12:35 pm
Hi guys, I have a 1985 transit MK2 single wheel, long wheel base. Could anyone tell me which master cylinder bore size I should buy? I believe it is either 22.2, or 23.8mm
Mikemax1984
Return to Mk 1 & 2
cron
