radiator for mk2 - mk3 ok ??
Postby GavSuz » Sun Nov 11, 2012 10:23 pm
needing a new rad for our mk2
can't seem to find one for a mk2 - will a mk3 do with making it fit ? can't see an overflow pipe out of the mk3 rad ?
any help would be good - Thanx
GavSuz
Re: radiator for mk2 - mk3 ok ??
Postby Mephilth » Wed Nov 14, 2012 11:05 am
hi,
i'm not sure about the dimesions of the mk3 rad but at least my mk3 diesel rad has an overflow pipe in the upper left corner (if you stand in front it)
Mephilth
Postby FredTransit » Wed Nov 14, 2012 12:03 pm
yeah most of our conversions have mk3 rads. All pintos should be the same too. Did you know the rad supports on a mk2 phase2 are adjustable? There are holes in the front panel to allow for wider rads.
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
