Mk2 Transit Front Cross Member
Re: Mk2 Transit Front Cross Member
Postby Muttley » Mon Sep 10, 2012 9:31 pm
Gawsh :oops: :lol: I do mobile too :wink:
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby Custard99 » Tue Sep 18, 2012 5:59 pm
Hi Mutley, Just joined forum having acquired a Transit Mark 2 'breadvan' minibus conversion. Runs ok but among other things needs a new front crossmember.
Are you able to fabricate one as they seem...er...a little rare!!
(Based Essex)
Custard99
Postby Muttley » Tue Sep 18, 2012 8:40 pm
Yes, no problem. Is it the whole thing or just outer bits, or just the centre bit under the radiator? I can come to you or you can come to me (South London) :)
Muttley
Postby Custard99 » Mon Sep 24, 2012 10:01 pm
Sorry for the delay in responding - lost ability to log in to forum for several days!!
It's the whole thing.
Probably easier if I give you my email adddress (billhiron@aol.com) just incase same problem repeats!!
Is it a standard pattern you can replicate or were there different varieties on different models?
Cheers
Bill
Custard99
Postby Muttley » Wed Sep 26, 2012 4:59 pm
I will cut out and replace exactly what was your original, all mountings and holes that were there before will be there afterwards. It will be made from 1.2mm steel which exceeds the original of 1mm :)
Muttley
Postby cardy58 » Thu Oct 04, 2012 11:01 pm
Helo I don't suppose you make the front spring hangers for the MK2
Thanks Norman
cardy58
Postby Muttley » Fri Oct 05, 2012 9:31 pm
cardy58 wrote:Helo I don't suppose you make the front spring hangers for the MK2
Thanks Norman
I would have to use modded MK3 hangers but it will look original :wink:
Muttley
Postby cardy58 » Tue Oct 09, 2012 1:55 pm
I am in Northern Ireland so getting to you might be difficult :D, what would you charge for a complete front cross member with spring hangers with postage to NI.
Thanks Norman
cardy58
Return to Mk 1 & 2
