Unleaded
Re: Unleaded
Postby whitemice » Wed Oct 31, 2012 7:50 am
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Re: Unleaded
Postby robbie.cee » Wed Oct 31, 2012 10:22 am
Wow that's quite a read Mark !
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Re: Unleaded
Postby whitemice » Wed Oct 31, 2012 11:29 pm
There are a few other interesting links lower down that one about the subject too.
No mention in them days of the hassle with ethanol in the petrol these days though. :mrgreen:
whitemice
Re: Unleaded
Postby whitemice » Thu Nov 01, 2012 12:47 am
One of the main things to do as part of regular routine maintenance is valve clearance checks whether noisy or not, they will indicate any recession occurring, as well as compression checks, i do both yearly on the V6.
whitemice
Re: Unleaded
Postby whitemice » Thu Nov 01, 2012 6:01 am
This is the base elements for most of the lead replacement additives out there.
Phosphorus.......................Motul...castrol valvemaster....STP
Potassium........................Nulon....redex......millenium.....morris
Manganese........................wynns....millers......carplan/carlube.......
Sodium............................redline
Out of all of it redline Sodium base is the most interesting and i'm going to experiment with it having scored 3x335ml ie. just over a litre at a price that beats the millenium i currently use in my fuel mixes for economy and the claim of equivalence to 3 --5gm of lead per gallon according to dose is better than the pre 2000 tetraethyl lead content which had been reduced to about 1.5gm from memory? ............ :?: I'll use up the millenium i've got then check valve clearances and start a test regime.
Millers is too uneconomical to my mind, although they seem to be addressing the ethanol issues, not too keen on the idea of manganese either. :mrgreen:
For potassium base the nulon is cheap and better than nothing and the re-formulated morris stuff looks reasonable too.
phosphorous old valvemaster can be got for £8 here http://www.bighealey.co.uk/sitemap
whitemice
Re: Unleaded
Postby robbie.cee » Thu Nov 01, 2012 9:46 am
Manganese was used to treat Drinking water but they stopped using it when they discovered it had a viagra effect on men
:shock:
Had
MAKE IT FIT
robbie.cee
Re: Unleaded
Postby whitemice » Thu Nov 01, 2012 3:45 pm
robbie.cee wrote:Manganese was used to treat Drinking water but they stopped using it when they discovered it had a viagra effect on men
:shock:
That explains everything, i thought i was getting stronger now that i don't need two hands to hold it Rob. :(
whitemice
Return to Mk 1 & 2
