Leaf springs
Re: Leaf springs
Postby Di Jack Regan » Mon May 13, 2013 11:34 pm
Thanks guys, great info as usual 8) This is when I went to France last month...................
And my girlfriend has gone to France tonight ALONE :oops: and driven it for the first time, again fully loaded.
I could not resist this opportunity :D
Di Jack Regan
Re: Leaf springs
Postby mb4ever » Tue May 14, 2013 4:32 am
Di Jack Regan wrote:Thanks guys, great info as usual 8) This is when I went to France last month...................
My sixpence says that if you moved the heavy part of your load further into the van, you would find a big improvement in attitude and handling Joe.
As a basic rule, the heavy stuff needs to go in front of the back axle.
To put it another way, the heavy stuff needs to go between the axles, and in the middle (left to right) of the vehicle.
mb4ever
Re: Leaf springs
Postby davev6newman » Tue May 14, 2013 9:02 pm
This was after i had new springs fitted. The gap under the wheel arch was increased by a good 2 inches more than it should be.
davev6newman
Re: Leaf springs
Postby mb4ever » Tue May 14, 2013 9:12 pm
davev6newman wrote:This was after i had new springs fitted. The gap under the wheel arch was increased by a good 2 inches more than it should be.
What did you reckon to them them please Dave?
mb4ever
Re: Leaf springs
Postby davev6newman » Tue May 14, 2013 9:39 pm
They were good springs and apart from the added height had no complaints with them. They were slipper springs and had a tendency to squeak badly if you never lubricated them up with spray white grease.
davev6newman
Re: Leaf springs
Postby mb4ever » Tue May 14, 2013 10:33 pm
davev6newman wrote:They were good springs and apart from the added height had no complaints with them. They were slipper springs and had a tendency to squeak badly if you never lubricated them up with spray white grease.
Thanks Dave.
What about body roll, and increased step height please?
How long are your legs by the way?
mb4ever
Re: Leaf springs
Postby davev6newman » Wed May 15, 2013 9:56 pm
It made no difference to body roll, best thing you can do there is fit new shocks all round. The step height was no problem to me as i used a set of caravan steps any how.
davev6newman
Re: Leaf springs
Postby mb4ever » Wed May 15, 2013 10:28 pm
davev6newman wrote:It made no difference to body roll, best thing you can do there is fit new shocks all round. The step height was no problem to me as i used a set of caravan steps any how.
Thanks Dave.
Did you fit new shocks when you fitted the springs then please?
mb4ever
Re: Leaf springs
Postby Di Jack Regan » Thu May 16, 2013 8:13 pm
Dave, can you please remove that picture, its making my trousers tight :P :P
Di Jack Regan
Re: Leaf springs
Postby davev6newman » Thu May 16, 2013 9:32 pm
you want more big boy? :lol:
davev6newman
Re: Leaf springs
Postby davev6newman » Thu May 16, 2013 9:37 pm
i replaced all the shocks before the springs, but it did help with the wallowing.
davev6newman
Return to Mk 1 & 2
