Hi All,
This is a very old thread - but we're having similar woes. I had a look at the temperature gauge on Transitandy's camper today and found the same problems.
Andy's camper....
http://fordtransit.org/forum/viewtopic.php?f=27&t=56747Bear in mind this is a Mk4 Banana in a Mk1 Chassis with a Mk1 cluster. However, it is absolutely clear that the original cluster has had separate fuel and temp gauges added at a later date. This could have been done when the Mk4 banana went in, or could have been due to a failure of the original gauges - I doubt we'll ever know.
The Mk4 temp sender is reading ~ 1k Ohms cold to ~ 250 Ohms warm. These are way out of range for the gauges described above (and I assume the original cluster). I don't think the sender is faulty... but if anyone does have a Mk4 kicking about,
I'd be really grateful to get a cold (and hot if possible) resistance across the sender just to confirm this.
If the sender is working correctly, I think the easiest option is to find a matched gauge as I simply don't have the skills to construct a voltage stabiliser and shunt for the original gauge - and even if I did, I don't know if the original gauge works anyway. I suspect not, due to the addition of the other gauges. The other gauges of course, being additions, are unidentifiable in any sensible form.
Andy is understandably keen to try to keep the camper cosmetically original where possible so we'd like to either get a gauge that matches the Mk4 which we can put into the original cluster, or a sender which fits the Mk4 thermostat housing and matches the original gauge range.
So, your quest for today
- Least preferable 'cos we don't know if the gauges work: ....Anyone know of a simple way to get a Mk4 Sender matched to a Mk1 Gauge?
- Preferred Option: Anyone know of any Fords (probably of the same era to the Mk4...1993) that ran a seperate temp gauge that matches a Mk4 sender? If so, we'll start looking around scrappies. It might be on an Escort, Orion, Granada whatever, if it works we'll find it.
- Last Option: Buy an aftermarket sender and gauge. Don't like this idea but will do if necessary, and it
should be the easiest. This raises questions.... how does the aftermarket sender fit? I doubt it will be the same thread/pitch as the existing sender... so does it go inline in a water hose or something?
Would really appreciate any thoughts chaps.... The temp gauge is the only thing holding Andy back from actually driving it any distance.
If it helps, Andy could put up some photos of the cluster and sender (as long as he sorts out that bloody auto-focus
Thanks in advance,
Bill
The Transitroen Driver
