bortaf wrote:Any help?
Unfortunetly, I don't think so..
I guess this isn't the same as my box.. Our's has an attached side plate, just below where the stick engages.
transitgeoff wrote:i take it you havent changed the stick position then lukethat box wont last long in there as the input shaft on a sierra is shorter and is not reaching into the spigot
and to change the stick you also need to change the tail section and i wouldnt advise a diy job on that
enjoy it while it lasts
travlinman wrote:transitgeoff wrote:i take it you havent changed the stick position then lukethat box wont last long in there as the input shaft on a sierra is shorter and is not reaching into the spigot
you got him again![]()
sum no and sum dont
sum no and sum dont
Luke wrote:this is the type 9 with the transit stick![]()
Muttley wrote:The Transit Type 9 box has a gear lever that comes up from underneath and bolts to the bottom of the bit you can see through. Hens teeth are pretty easy to find compared to a Type 9 gear leverYou will also need the correct cross member and prop if you dont already have them
5 speed type 9 boxes fitted to MK3 Transits 1986 to about 1990.
DodgeRover wrote:I think the argument against the type 9 was that it can let go with no warning when in a transit, I know they'll handle big bhp in escorts/ sierra's etc but its the torque and a heavily loaded van that can be the end of them.
FredTransit wrote:sorry but I would live with a plate in the floor over a box that could go bang without warning!
