Noisy front suspension
Postby bov783 » Sun Jul 01, 2012 9:03 pm
Hi all
I am at my witts end !! I run a 1978 Mk2 Travelhome. For the past couple of years it has developed a creak / groan from the front passenger side.I have spent hours trying to find the problem but everything I do has no effect. It sounds like a shock absorber or worn out bush. Things i have done are 1 replace all shocks and bushes. 2 Replace all shackle bushes. 3 Replace all stearing joints. 4 re shim kingpins.
The step and sill where very badly corrided so these have been replaced. I hoped the mot bloke would fail it but it passed.
I found the rubber bush on the center propshaft bearing had gone which I thought could well be the problem. As the shaft moves it fouled the metal frame. Just done a road test and the noise is as bad as ever.
If anyone lives near Lincoln will pay to have them have a listen cos it's beaten me !!
Best regards
Phil
bov783
Re: Noisy front suspension
Postby montym100 » Mon Jul 02, 2012 7:49 pm
Just a guess, engine mounts?
montym100
Postby Ken B » Mon Jul 02, 2012 8:05 pm
Are your front springs single leaf or multileaf. If its multi could be them grinding together.
Ken B
Location: Spalding lincs. The land that time has forgotton.
Postby bov783 » Mon Jul 02, 2012 9:13 pm
Hi ken they are single. I recon it could be the bush at the front of the spring. Not sure what sort of a job it is to remove. My biggest problem is lifting the van from the chassis. I can jack it up from the axil fine but I don't think the front cross member will hold it !!
bov783
Postby yogi » Mon Jul 02, 2012 10:50 pm
try going over each pivot bush and bearing with excessive amounts of wd40 one at a time and road testing after and see if the sound changes if it dose its prob that joint
yogi
Postby bov783 » Tue Jul 03, 2012 4:39 am
Good idea I will give that a go when I get time thanks
bov783
Postby bov783 » Mon Jul 16, 2012 1:51 pm
Finally found the noise. I just happened to look under the van after another noisy trip to Chatsworth and noticed the rear flange bolts on the axil were shining. Turns out the handbrake cable was fouling the bolts as the axil went up and down. This caused the rod to vibrate through the frame !!!
bov783
Postby baconsdozen » Tue Jul 17, 2012 9:21 am
Its suprising how noise travels sometimes on a vehicle.I had a bracket fail so that the handbrake cable occasionly rubbed on the inside of a tyre.
It too seemed to be coming from somewhere at the front.
baconsdozen
Return to Mk 1 & 2
