How I tune a V6 Essex 3.0L.
Re: How I tune a V6 Essex 3.0L.
Postby robbie.cee » Tue Apr 15, 2014 9:02 pm
Bloomin expensive too!
Money well spent tho!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Neil » Tue Apr 15, 2014 9:33 pm
conrod wrote:Probably still a good improvement Neil. They would add 25hp to an otherwise stock Capri HC engine, but the biggest gain is in low-mid range torque. Apparently the distribution of air and fuel in the stock single carb V6 manifold is terrible, the centre cylinders get the lions share of the air and fuel, and the end cylinders are down quite a large percentage, less than 90% of what the centre cylinders get. The rear two cylinders run hotter as they tend to run leaner. The "W" deflector fitted by Ford under original twin choke was an attempt to alleviate this a bit. I can't imagine how bad the single choke setup would be, as the carb is very close to the front of the engine on these manifolds, and not centred like the twin choke. The triple carb setup gives one throat for each cylinder, and apparently wakens the engine up everywhere, not just top end power. I have not fitted and tried them yet, so cannot say this from my own experience, but a few people I know who have had them say the difference is significant and very noticable. And they look cool too :)
Conrad
did ford fit the webber on the transit mk 2 :?: I can only say mine run fine on the single carb which had a governor fitted below it from new,, im sure the v6 ambulances had the single carb too,, I only went to webber as I could not find a new single at the time,, the webber does go better mid range :)
Neil v6
Neil
Postby davev6newman » Wed Apr 16, 2014 9:23 pm
My Mk2 V6 Camper has a Weber so does my Mk1 V6 and my previous Mk1 V6 Had a Weber too
davev6newman
Postby Neil » Wed Apr 16, 2014 9:40 pm
davev6newman wrote:My Mk2 V6 Camper has a Weber so does my Mk1 V6 and my previous Mk1 V6 Had a Weber too
yes but fitted by ford :?: or changed as new ford carbs are hard to find and have been for years that's why I went the webber route could nt find a ford carb until now :D
Neil v6
Neil
Postby Leeday » Wed Apr 16, 2014 10:59 pm
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Postby conrod » Thu Apr 17, 2014 10:50 am
Leeday wrote:http://www.ebay.co.uk/itm/Ford-Essex-V6-Triple-Webers-/141257885599?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20e3a0479f
ooooh nice :D
How much :shock:
yep they are pricey! I paid as much for my carb setup as I did for my Mk2 van. Wasn't as much as those though!......
Single choke setup off an ambo here:
http://www.ebay.co.uk/itm/Essex-V6-sing ... 3cdfba2436
conrod
Postby Neil » Thu Apr 17, 2014 5:18 pm
that will be knackered that's why they are upgrading like everyone does as they can t find a new single
Neil v6
Neil
Postby baconsdozen » Thu Apr 17, 2014 5:49 pm
The rear cylinders also run hotter because of their position tucked up close to the bulkhead and shielded from air flow.
baconsdozen
Postby Leeday » Tue Mar 15, 2016 1:03 am
conrod wrote:I just bought these, 42 DCNF's on an original Ford manifold. That would wake the Tranny up a bit :)
Conrad
P.S. yes I know they are on backwards!
Did you get these fitted?
Leeday
Postby whitemice » Wed Mar 16, 2016 2:48 am
webers are gay
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby Leeday » Wed Mar 16, 2016 11:05 pm
whitemice wrote:webers are gay
:lol: :lol:
What is your preference then?
Leeday
Postby DodgeRover » Thu Mar 17, 2016 11:17 pm
Real men use gas carbs ;) like a nice Impco or OHG....
DodgeRover
Postby apples26 » Sun Jul 30, 2017 5:11 pm
I've got a Essex v6 with a 38dgas that is bogging down on acceleration
I think plugs leads fine and I've just done away with points and fitted electronic ignition but still pretty much the same so I'm presuming carb related
Where should I start? It starts runs idled lovely
http://WWW.NEEDATOW.CO.UK
apples26
Postby Neil » Sun Jul 30, 2017 6:27 pm
apples26 wrote:I've got a Essex v6 with a 38dgas that is bogging down on acceleration
the v6 Essex in a transit from ford had a single carb and lower compression engine I fit a 38 weber on mine and had the same issues so I went back to single carb and points the way it was built and no further problems if the transits had an engine swap from a capri or Granada then the 38 should be fine I think it has to do with the way its jetted
Neil v6
Neil
Postby apples26 » Sun Jul 30, 2017 6:35 pm
Yes capri lump
What about timing? It's been so long I can't remember how to use the lamp, mines an old britool one not digital it's got a moving needle
On running engine I remove vacuum from dizzy rev it to 3000 and setting timing lamp to 13btdc I move dizzy till the Marks align on pulley is that correct? Or am I supposed to do it idle?
apples26
Return to Mk 1 & 2
