Flywheel ring gear
Flywheel ring gear
Postby j6393 » Sat Oct 13, 2012 11:48 am
Every so often the starter on my 1967 Transit (V4) doesn't engage and it seems that the ring gear is loosing a tooth.
Just moving the engine over a couple of degrees allows the starter to engage but ring gears for a V4 are apparently hard to get in Australia.
Does anyone know if the ring gear can be turned or if the same ring gear might be fitted to another model?
j6393
Re: Flywheel ring gear
Postby robbie.cee » Sat Oct 13, 2012 10:44 pm
i had same issue - starter missed gear(it seemed) but if i stuck in 3rd with foot off clutch, started it would catch, and if i pressed clutch in at right time van would always turn over.. was convinced it was the ring gear
BUT
when i swapped engines over i examined the ring gear- was fine was actually starter gear was fkd....
check your starter it might just need new drive gear!!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby j6393 » Sun Oct 14, 2012 12:05 pm
Thanks Robbie.
Originally I blamed the starter and got a brand new one but still had the problem - rock it in gear forwards or backwards or simply pull the fan belt over a couple of inches to turn the motor over slightly and no problem starting.
Must be time to pull the bell housing & gearbox off to have a good look.
j6393
Postby robbie.cee » Sun Oct 14, 2012 2:13 pm
You can get a new ring gear , crack the old one off,
Heat up the new one whilst laid on Flywheel,
when expanded enough should slip down into place
Had
MAKE IT FIT
robbie.cee
Return to Mk 1 & 2
