FredTransit wrote:dont know if or how often you turned over the engine. First try it by hand to check its not siezed. Piston rings can gum up and snap if you shock them! Yours has been laid up a long time so fresh petrol is a must. Traces wont hurt
FredTransit wrote:FredTransit wrote:dont know if or how often you turned over the engine. First try it by hand to check its not siezed. Piston rings can gum up and snap if you shock them! Yours has been laid up a long time so fresh petrol is a must. Traces wont hurt
YellowTransit wrote:Hi there,
My name is Hans and I live in The Netherlands.
baconsdozen wrote:I like to take the plugs out,pull the feed off the coil and spin the engine on the starter untill the oil light goes out.
Best of luck,hope it all goes well for you.
