banana engine into mk2 ? plus steering rack
Postby GavSuz » Wed Oct 31, 2012 9:33 pm
how hard or easy is it to put a 2.5 diesel banana engine and steering rack system into a mk2 ?
heard theres very little electrics involved - how about engine and box mounts ?
exhaust manifold mounting up the same point ?
radiator ? - could do with new one anyway as found it got a hole in
box to prop shaft mounting ? - same ? need new bearings/rubbers anyway
steering system - suppose new hubs etc off mk3 will be needed
Thanx
GavSuz
Re: banana engine into mk2 ? plus steering rack
Postby big gux » Sat Nov 10, 2012 6:39 pm
hi its not as hard as you think my mk2 was petrol it now run a 2.5 DI and a mt75 5 speed box use early doughnut engine mounts i would do it for ya really you need a early mk3 donor vehicle that has rotted out with a decent e/box in my 81 mk you see in the pic is a 92 engine and box and its still on same front springs etc my next add on is front struts off a mk3 and power steering exhaust ya just cut and shut too suit
big gux
Postby FredTransit » Sat Nov 10, 2012 7:12 pm
the engine is the easy bit, the rack conversion is harder work. It depends what work you have done in the past and your skill level
FredTransit
Mk2 Trannyist
Postby GavSuz » Sat Nov 10, 2012 10:35 pm
thanx for the info
main reason for wanting to do it is for parts - and also steering rack is easier to fix/replace ( once in )
current 2.4d engine is good tho - only 78k ( in km so presume miles is lower )
GavSuz
Postby blue estate » Sat Nov 10, 2012 10:39 pm
GavSuz wrote:thanx for the info
48467miles :wink: :shock:
blue estate
Postby GavSuz » Sat Nov 10, 2012 10:44 pm
is that mine or urs ??
GavSuz
Postby big gux » Sat Nov 10, 2012 10:46 pm
is yours a twin wheeler transit mate
big gux
Postby GavSuz » Sat Nov 10, 2012 10:48 pm
u mean 2 wheels each side at the rear ?
yes if thats what it means - sorry never owned a transit before
GavSuz
Postby blue estate » Sat Nov 10, 2012 10:48 pm
Your's
blue estate
Postby GavSuz » Sat Nov 10, 2012 10:50 pm
blimey - thats nothing
thats like 2k a year lol
got every MOT to prove it all too
GavSuz
Postby FredTransit » Sat Nov 10, 2012 10:58 pm
on the basis of that mileage, why make that much work for yourself? Serviced properly the yorkie will plod on and the steering box is good for about 100k miles. At least!!
FredTransit
Mk2 Trannyist
Postby GavSuz » Sat Nov 10, 2012 11:01 pm
yeh think i'l stick with the engine
the steering is horrible tho - really woolly and wobly
already ordered a new drag link end that connects to steering box arm as it was all perrished
if that cures the problem then i'l be happy - if not i'l have to fork out for recon steering box
GavSuz
Postby big gux » Sun Nov 11, 2012 12:43 pm
A YORKS BEST FRIEND IS A CAN OF BRADEX EASY START MATE GET IT OUT AND PUT A DI IN HER
big gux
Postby FredTransit » Sun Nov 11, 2012 1:28 pm
have you tried adjusting the steering box? I would be surprised if its cattled. ........
FredTransit
Mk2 Trannyist
Postby GavSuz » Sun Nov 11, 2012 2:26 pm
how do u adjust them ?
GavSuz
Return to Mk 1 & 2
