Steering box adjustment
Postby bov783 » Sun Nov 11, 2012 8:11 pm
Hi all
Just a bit of advise. My 1978 travel home has a lot of slack on the steering box. I can see what seems to be an adjuster. I looks like a screw with a locking bolt around it . Is is worth touching or best left alone. It drives ok. Also dose it run in oil which should be checked ??
Many thanks
Phil
bov783
Re: Steering box adjustment
Postby carnut1100 » Sun Nov 11, 2012 10:49 pm
That's the adjuster.
Loosen lock nut, adjust then tighten locknut.
Don't go too far though.
If you do you will get tight spots in the steering.
Probably won't be able to get all the play out without going too far but you'll get some out.
They do have oil but I'm at work and not near the manual to check what grade.
1979 Mk2 Truck Project thread here
carnut1100
Postby bov783 » Sun Nov 11, 2012 10:52 pm
Many thanks for that will have a go when I get time.
Regards
Phil
bov783
Postby baconsdozen » Mon Nov 12, 2012 9:31 am
Some use a heavy oil,some use grease.
baconsdozen
Return to Mk 1 & 2
