DougT wrote:Have you got one of the water fed - oil cooler things between the block and the filter ?
Ford seem to fit them to everything and I have seen them disintegrate.
Doug
FredTransit wrote:I would be surprised if the head (heads?) are warped as it/they are cast iron!
WHAT ENGINE IS IT?!!
MECHANIC wrote:Another cause of water mixing with the oil on the Essex, was a failed inlet manifold gasket, and this tended to empty the radiator quicker than head gasket failure
FredTransit wrote:MECHANIC wrote:Another cause of water mixing with the oil on the Essex, was a failed inlet manifold gasket, and this tended to empty the radiator quicker than head gasket failure
WOW you waited almost 5 years to the day to make your first post??? Welcome anyway!!
baconsdozen wrote:I wonder if he ever got it sorted out?.
