MK1 indicator stalk
MK1 indicator stalk
Postby Di Jack Regan » Wed May 08, 2013 5:28 pm
Does anyone know what the Lucas part number is for a MK1 indicator stalk. My one is non accessible at the moment as the van is elsewhere :-(
Grassy Arse
Joe
Di Jack Regan
Re: MK1 indicator stalk
Postby mb4ever » Wed May 08, 2013 6:07 pm
mb4ever
Postby Neil » Wed May 08, 2013 7:42 pm
LOOKS LIKE IT
Neil v6
Neil
Postby Di Jack Regan » Wed May 08, 2013 10:39 pm
Hmmmm, I was watching this one, but they are both different :roll:
http://www.ebay.co.uk/itm/261168094480? ... _348wt_971
Different as in the block connector.......
Di Jack Regan
Postby Neil » Thu May 09, 2013 7:08 am
early ones are left mounted and later ones right mounted so they may have changed the connecter too :!: whats wrong with yours :?:
Neil v6
Neil
Postby Di Jack Regan » Thu May 09, 2013 9:55 am
Hi Neil, I found that at night when I flick it down to high beam I loose all my lights, until I jiggle it a bit then they come on. I've taken it apart and cleaned all the terminals and contacts them lightly greased it and it does the same. So thought I'd go down the new stalk route :-/
Ill need to get to mine somehow before it ends and check the block connector.
Di Jack Regan
Postby mb4ever » Thu May 09, 2013 10:22 am
Di Jack Regan wrote:Hi Neil, I found that at night when I flick it down to high beam I loose all my lights, until I jiggle it a bit then they come on. I've taken it apart and cleaned all the terminals and contacts them lightly greased it and it does the same. So thought I'd go down the new stalk route :-/
Is there a coil spring inside yours Jack?
If so, what do you reckon to stretching it a bit?
Gives 'em an extra bit of grunt when it comes to closing the contacts. :wink:
mb4ever
Postby Neil » Thu May 09, 2013 2:08 pm
yes ive had the same problem before and also horn working now and again ,, my auto sparky stripped it down and did something to sort it and it did but a new one should be right
Neil v6
Neil
Return to Mk 1 & 2
