Refurb carb kit for a mk2 2.0 1981
Postby Riky » Wed May 15, 2013 12:30 pm
I am after a refurb kit for my carb, I am trying to keep it all original so would like to refurb instead of replace. If any knows of a good place for spares it would be appreciated.
Also can any one recommend some Transit clubs to join and info on shows etc.
Cheers.
Riky
Re: Refurb carb kit for a mk2 2.0 1981
Postby mb4ever » Wed May 15, 2013 3:32 pm
Riky wrote:I am after a refurb kit for my carb, I am trying to keep it all original so would like to refurb instead of replace. If any knows of a good place for spares it would be appreciated.
Cheers.
You are at the best site here Riky.
The others don't compare. :)
Shows here : -
viewforum.php?f=20
Depends what you mean by re-furb.
Is your spindle loose so you want to replace it, or are you looking for gaskets and jets?
Some stuff here: -
eBay listings
eBay listings
mb4ever
Postby Riky » Wed May 15, 2013 3:44 pm
Thanks for the reply mb4ever, I am looking to strip the carb down completely and refurb to new. I am really after a complete kit of gaskets, rings and jets if possible.
Riky
Postby Neil » Wed May 15, 2013 4:28 pm
google Andrew turner carbs give him a bell you may get a replacement from southern carbburetas
Neil v6
Neil
Postby mb4ever » Wed May 15, 2013 4:47 pm
Riky wrote:Thanks for the reply mb4ever, I am looking to strip the carb down completely and refurb to new. I am really after a complete kit of gaskets, rings and jets if possible.
The only reason I know to completely re-furb a carb is because the choke spindle is loose in the carb body Riky, and that's a job and a half.
If your spindle is loose, I suggest you take Neil's advice and get an exchange carb.
Apart from that, I just reckon to give them a bit of a clean, new gaskets, and new parts for the accelerator pump.
Plus reseat the valve that's operated by the float with a gently tap on it's end.
After that, I reckon to fine tune the float level to suit.
mb4ever
Postby Riky » Wed May 15, 2013 11:00 pm
Thanks mb4forever for the advice, I will get a gasket kit and give the carb a good clean.
May need a bit of help later when it is in bits..... :lol:
Riky
Postby mb4ever » Thu May 16, 2013 8:30 am
Riky wrote:Thanks mb4forever for the advice, I will get a gasket kit and give the carb a good clean.
Have you considered taking photographs at each stage as you strip your carb Riky?
mb4ever
Postby mb4ever » Thu May 16, 2013 4:43 pm
Have you heard of ultrasonic cleaners Riky?
I've no experience of them, but I understand that they clean carbs pretty well.
These are all completed listing to show what they sell for.
Anyone tried one please :?:
There seem to be some 2nd hand bargains on ebay.
eBay listings
mb4ever
Postby Neil » Thu May 16, 2013 6:52 pm
yes use one all the time
Neil v6
Neil
Postby Riky » Thu May 16, 2013 9:17 pm
Hi all,
I will take some photos of the mess I will probably create and publish them on the web. I will hopefully tackle this next month so I will keep you all updated.
Thanks for all the advice, if I learn anything of interest I will let you know.
Riky
Postby mb4ever » Thu May 16, 2013 9:34 pm
Neil wrote:yes use one all the time
Thanks Neil, which sort have you got please?
mb4ever
Return to Mk 1 & 2
