Mk1 4 pot Disc brake conversion
Re: Mk1 4 pot Disc brake conversion
Postby FredTransit » Fri Feb 07, 2014 5:36 pm
little Steve? He knows his stuff. Why didnt yer just ask me? Mention Fred with the vans sent yer.
PS, I'm not a bloke.......
FredTransit
Mk2 Trannyist
Postby ClassicRS » Fri Feb 07, 2014 6:05 pm
FredTransit wrote:little Steve? He knows his stuff. Why didnt yer just ask me? Mention Fred with the vans sent yer.
:shock: ......naaaaaah, a babe hot for vans ??? noooo waaaaaaay ! :lol: :lol: :lol:
ClassicRS
Postby FredTransit » Fri Feb 07, 2014 8:54 pm
LMAO! Thanks er I think..... I did have my moments!! :D
FredTransit
Mk2 Trannyist
Postby ClassicRS » Sat Feb 08, 2014 3:13 pm
FredTransit wrote:LMAO! Thanks er I think..... I did have my moments!! :D
R.E.S.P.E.C.T. :wink:
Thnaks Fred. Got the bits last night so "Chantelle" - the 3 liter Essex girl will be back on the road Tuesday :D
ClassicRS
Postby Aussie Ice Cream Van » Sun Mar 08, 2015 1:20 am
Hi guys, I would like to know I could obtain a pair of Black diamond rotors, or another brand rotor that is ventilated and cross drilled, to suit the mk1/2 transit, just like Conrad did in this thread, as I am looking at doing the same conversion, cheers
Postby Aussie Ice Cream Van » Sat Mar 21, 2015 6:39 am
Hi guys, I have tried to contact user '"Conrod", about how I could get a set of the ventilated slotted rotors, but no response, can anybody please help me, as I will be doing this LDV conversion, cheers
Postby conrod » Mon Apr 13, 2015 11:01 am
sorry, haven't been on here for a while. Have answered your pm :)
conrod
Postby Greg L. » Mon Apr 27, 2015 8:01 pm
Please could you share the information here ?
I'm from France and I also have a MK1 LWB, and I'm looking for a bolt-on way to upgrade the brakes.
The other option I have is to swap my MK2 dual (four ?) pot front drive train.
Greg L.
Postby Vandalism » Tue Apr 28, 2015 9:48 am
ive got a mk2 front axle on my mk1 as a break upgrade as the mk1 one had drums
Postby Greg L. » Wed Apr 29, 2015 2:55 pm
Could you confirm it's a bolt-on swap ?
Would the LDV conversion be a better swap than the MK2 one ?
Greg L.
Postby Vandalism » Wed Apr 29, 2015 10:19 pm
mk2 axle is amlost a bolt on job but the mk2 axle has a flat section where it bolts to the chassis but the mk1 has an angled section so you have to make up a spacer plate thats flat on one side and angled on the other if that makes sence
id imagine an ldv one would involve a bit more modifying
Postby dlonewolf86 » Mon Dec 12, 2016 7:22 am
Holy thread ressurrection batman!
Sorry to drag this up guys but can anyone confirm if the LDV calipers are a bolt on fit?
As I've found them for sale from here - http://brakeparts.co.uk/#!/shop/LDV/CON ... 0cylinders
And I'm very interested in fitting them to my Mk2,which I'll be using as a recovery truck.
Also does anyone have the part numbers for the brake pads?
Thanks in advance!!
dlonewolf86
Postby conrod » Wed Dec 14, 2016 11:57 pm
yep LDV calipers bolt straight on! Just be sure to get the ones with spacers if you are using vented discs, or without if running solid discs. Also, better to find a pair with one inlet brake pipe, as some had two (just as the Transit did!) Sorry can't remember pad numbers, but should be easy to find out.
conrod
Postby Altransit » Thu Dec 15, 2016 11:00 am
APEC Pad 61 is correct for the 4 pot calipers, (that was the brand that I used to use!) Pad 60 was for the single pot caliper.
You should be able to cross reference these :idea:
Postby dlonewolf86 » Fri Dec 16, 2016 5:22 am
Thanks for your help guys!
Conrod, the single pipe calipers are further down that page. They're the ones I'll be getting to save a lot of mucking about!
Thanks again!
dlonewolf86
Return to Mk 1 & 2
